    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
      marcosrodrigues
      Seems very promising, Wikii. Thank you.
      | menos é mais
        it doesn't work with a straight line like in your example
        Your are not alone 😄
        And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
        yesno.skp
          Interesting plugin but this is what I get.
          http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
          http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
          http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
          http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
          • W Offline
            wikii
            select a face without it's border
              thank you. that works.
              • W Offline
                watkins
                Dear Pilou,
                Thanks for posting the .zip file.
                Regards,
                Bob
                • free agentF Offline
                  free agent
                  hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  • jujuJ Offline
                    juju
                    We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                      cyan.archnet
                      simply "AMAZING", will give it a try, THANKS A LOT !!
                        dirkkkk
                        When I am using the plug in I get a bug splat... don`t know why 😞
                        Could It be because I am using a 64 bit system,
                        Thanks,
                          or it conflicts with another plugin.
                          You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                          • N Offline
                            notareal
                            Nice work!
                            • H Offline
                              herodes
                              I am having difficulties running this script. Inside the latest Far.rar I find:
                              inputbox.rb -- for the interface
                              FollowAndRotate_en.rbs -- the English version of the script
                              FollowAndRotate_cn.rbs -- the Chinese version of the script
                              far.skp -- example output
                              I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                              In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                              load "FollowAndRotate_en.rbs"
                              Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                              RBS1.0
                              C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                              RBS1.0
                              C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                              (eval);87
                              can you help me,...?
                              %(#BFBFBF)[http://arhitektonas.blogspot.com
                              I know me,... I am that guy...
                              • W Offline
                                wikii
                                To load a rbs file,you can try to use Sketchup.load
                                  And for the little problem of orientation?
                                  • H Offline
                                    herodes
                                    Thanks for answering.
                                    I tried the suggesting and now I get :
                                    Sketchup.load "FollowAndRotate.rbs"
                                    false
                                    ... and there is still nothing in the "Plugins" menu.
                                    How did all the others get it working ?
                                    • H Offline
                                      herodes
                                      Sorry for bumping this thread.
                                      Please help.
                                        Daniel S
                                        Herodes:
                                        I think that you don´t install it well
                                        Put the three files in your plugin folder
                                        inputbox.rb
                                        Perhaps this fix your problem.
                                        Daniel S
                                        • H Offline
                                          herodes
                                          @Daniel S: Thanks it did require that the FollowAndRotate_cn.rbs is in the same folder. That solved it thanks a lot.
                                          It is rather weird that that both scripts are required.
                                            rjb
                                            hi!
                                            this is an awesome plugin.. was able to do lots of things with it..
                                            but m unable to make a fluted tapering column yet..
                                            please guide me if anyone knows the trick....
                                            • 11
                                            • 2 / 11
