    [Plugin] follow me rotate
    211 Posts 79 Posters 280.0k Views 79 Watching
    • C
      cyan.archnet
      simply "AMAZING", will give it a try, THANKS A LOT !!
        dirkkkk
        When I am using the plug in I get a bug splat... don`t know why 😞
        Could It be because I am using a 64 bit system,
        Thanks,
        • GaieusG
          or it conflicts with another plugin.
          You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
          • N
            notareal
            Nice work!
            • H
              herodes
              I am having difficulties running this script. Inside the latest Far.rar I find:
              inputbox.rb -- for the interface
              FollowAndRotate_en.rbs -- the English version of the script
              FollowAndRotate_cn.rbs -- the Chinese version of the script
              far.skp -- example output
              I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
              In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
              load "FollowAndRotate_en.rbs"
              Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
              RBS1.0
              C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
              RBS1.0
              C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
              (eval);87
              can you help me,...?
              %(#BFBFBF)[http://arhitektonas.blogspot.com
              I know me,... I am that guy...
              • W
                wikii
                To load a rbs file,you can try to use Sketchup.load
                  And for the little problem of orientation?
                  • H
                    herodes
                    Thanks for answering.
                    I tried the suggesting and now I get :
                    Sketchup.load "FollowAndRotate.rbs"
                    false
                    ... and there is still nothing in the "Plugins" menu.
                    How did all the others get it working ?
                    • H
                      herodes
                      Sorry for bumping this thread.
                      Please help.
                        Daniel S
                        Herodes:
                        I think that you don´t install it well
                        Put the three files in your plugin folder
                        inputbox.rb
                        Perhaps this fix your problem.
                        Daniel S
                        • H
                          herodes
                          @Daniel S: Thanks it did require that the FollowAndRotate_cn.rbs is in the same folder. That solved it thanks a lot.
                          It is rather weird that that both scripts are required.
                            rjb
                            hi!
                            this is an awesome plugin.. was able to do lots of things with it..
                            but m unable to make a fluted tapering column yet..
                            please guide me if anyone knows the trick....
                            • MALAISEM
                              MALAISE
                              So useful, really impressive 👍 👍
                              It could be also a good idea to display a kind of counter
                              in order to avoid any operation during the calculation
                              ( let's see some Didier 's Plugins like terrain reshaper )
                              ----------------80% achieved..
                              MALAISE 😄
                              • B
                                bianhai
                                follow me rotate tutorials
                                http://www.sketchupbbs.com/thread-13577-1-1.html
                                http://www.sketchupbbs.com/attachments/month_0809/20080927_f20be19093c967fcf1a22HBisFh3rjMv.gif
                                SUTOOL2009 tutorials
                                see here blog:
                                http://www.sketchupbbs.com/Blog/?54739/
                                  silver_shadow
                                  hi bianhai
                                  what is that side panel thing you are using in your video?
                                  • B
                                    bianhai
                                    side panel is SUTOOL2009
                                      Really cool plugin. Though, there's some odd triangulation some times. Looks like half of it ends up smooth, but the other half of the geometry ends up with sharp jagged triangulation.
                                        silver_shadow
                                        is it a free plugin 😄?
                                          rufy
                                          nice plugin 👍
                                          by the way,what is SUTOOL 2009? it is new plugin ?, i saw the toolbar at the video by bianhai, i search in google, i found it , i know that site but i can understand chinese languange, 🎉
                                          • F
                                            Frank0503
                                            @wikii said:
                                            It is still in developing, here is the current version.
                                            Hello, I'm a newcomer. That's a pretty interesting things. I've already download your product to my computer, thank you so much. But I don't know use it to my sketchup how, can U show me the way to attack it to Sketchup software and how to control it 😕
                                            • 11
                                            • 2 / 11
