    [Plugin] follow me rotate
    211 Posts 79 Posters 280.0k Views 79 Watching
    • plot-parisP
      plot-paris
      phantastic plugin Wikii! thanks for sharing 😍
      however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
      http://img205.imageshack.us/img205/3448/far01kh7.jpg
      and I have a suggestion for a future update:
      if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
      would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
      or even better, could you change the script to allow the use of several seperate faces?
      http://img87.imageshack.us/img87/8549/far02vh5.jpg
      • W
        watkins
        Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
          Funny πŸ‘ β˜€ 😎
          Done πŸ˜‰
          Far.zip
          • W
            wikii
            Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
            • plot-parisP
              plot-paris
              weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
              but arround a curve it looks really cool! πŸ˜„
                marcosrodrigues
                Seems very promising, Wikii. Thank you.
                | menos Γ© mais
                  Your are not alone πŸ˜„
                  And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
                  yesno.skp
                    Interesting plugin but this is what I get.
                    http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
                    http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
                    http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
                    http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
                    • W
                      wikii
                      select a face without it's border
                        thank you. that works.
                        • W
                          watkins
                          Dear Pilou,
                          Thanks for posting the .zip file.
                          Regards,
                          Bob
                          • free agentF
                            free agent
                            hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                            • jujuJ
                              juju
                              We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                              • C
                                cyan.archnet
                                simply "AMAZING", will give it a try, THANKS A LOT !!
                                  dirkkkk
                                  When I am using the plug in I get a bug splat... don`t know why 😞
                                  Could It be because I am using a 64 bit system,
                                  Thanks,
                                  • GaieusG
                                    or it conflicts with another plugin.
                                    You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                                    • N
                                      notareal
                                      Nice work!
                                      • H
                                        herodes
                                        I am having difficulties running this script. Inside the latest Far.rar I find:
                                        inputbox.rb -- for the interface
                                        FollowAndRotate_en.rbs -- the English version of the script
                                        FollowAndRotate_cn.rbs -- the Chinese version of the script
                                        far.skp -- example output
                                        I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                                        In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                                        load "FollowAndRotate_en.rbs"
                                        Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                                        RBS1.0
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                                        RBS1.0
                                        C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                                        (eval);87
                                        can you help me,...?
                                        %(#BFBFBF)[http://arhitektonas.blogspot.com
                                        I know me,... I am that guy...
                                        • W
                                          wikii
                                          To load a rbs file,you can try to use Sketchup.load
                                            And for the little problem of orientation?
                                            • 11
                                            • 2 / 11
