    [Plugin] follow me rotate
    211 Posts 79 Posters 252.1k Views 79 Watching
    • W Offline
      watkins
      Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
        Funny πŸ‘ β˜€ 😎
        Done πŸ˜‰
        Far.zip
        • W Offline
          wikii
          @plot-paris said:
          and I have a suggestion for a future update:
          if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
          would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
          Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
          • plot-parisP Offline
            plot-paris
            weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
            but arround a curve it looks really cool! πŸ˜„
              marcosrodrigues
              Seems very promising, Wikii. Thank you.
              | menos Γ© mais
                Your are not alone πŸ˜„
                And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
                yesno.skp
                  Interesting plugin but this is what I get.
                  http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
                  http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
                  http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
                  http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
                  • W Offline
                    wikii
                    select a face without it's border
                      thank you. that works.
                      • W Offline
                        watkins
                        Dear Pilou,
                        Thanks for posting the .zip file.
                        Regards,
                        Bob
                        • free agentF Offline
                          free agent
                          hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                          • jujuJ Offline
                            juju
                            We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                              cyan.archnet
                              simply "AMAZING", will give it a try, THANKS A LOT !!
                                dirkkkk
                                When I am using the plug in I get a bug splat... don`t know why 😞
                                Could It be because I am using a 64 bit system,
                                Thanks,
                                  or it conflicts with another plugin.
                                  You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                                  • N Offline
                                    notareal
                                    Nice work!
                                    • H Offline
                                      herodes
                                      I am having difficulties running this script. Inside the latest Far.rar I find:
                                      inputbox.rb -- for the interface
                                      FollowAndRotate_en.rbs -- the English version of the script
                                      FollowAndRotate_cn.rbs -- the Chinese version of the script
                                      far.skp -- example output
                                      I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                                      In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                                      load "FollowAndRotate_en.rbs"
                                      Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                                      RBS1.0
                                      C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                                      RBS1.0
                                      C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                                      (eval);87
                                      can you help me,...?
                                      %(#BFBFBF)[http://arhitektonas.blogspot.com
                                      I know me,... I am that guy...
                                      • W Offline
                                        wikii
                                        To load a rbs file,you can try to use Sketchup.load
                                          And for the little problem of orientation?
                                          • H Offline
                                            herodes
                                            Thanks for answering.
                                            I tried the suggesting and now I get :
                                            Sketchup.load "FollowAndRotate.rbs"
                                            false
                                            ... and there is still nothing in the "Plugins" menu.
                                            How did all the others get it working ?
                                            • 11
                                            • 2 / 11
