[Plugin] UVTools v0.1
Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
It's happening too with UVTools v0.2 , -
It's happening too with UVTools v0.2 ,Oops...Sorry It's working pretty well on SU8 now, when i try to using it with Jeff Hammond Tips
Where Is the URL for download
Does this still work with SU8 on windows?
The plugin doesn't start, no menu is created.
It works perfectly you must have installed it incorrectly.
I use it everyday on v7, v7.1 and v8
Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
Ignore me, it is working, just not the UI I was expectingall good
I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much. -
It's attached to the first post with a
icon.
Generally this is the way authors publish and keep their plugins updated here so always look in the first post. -
BIGthanks mate!
I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
Eric
http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
Thanks in advance
(would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
I don't understand how to use the plugin.
I installed it,I get the new context menu.
I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
Nothing happens. -
Why would you install a plugin if you don't know what it is...?
Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...Try applying a bitmap texture to a sphere or a cylinder...
It's important that it's not just a color but a bitmap texture...
You'll see that the texture looks odd on such shapes...
Now click the sphere to select it...
Right-click it an from the submenu select UV tools and then select i.e. spherical...
You'll see that the texture looks correct now... -
Thanks A lot !
Downloading. . . .
Hi All,
Since I use Artisan, I have the need to improve my uv-texturing skills
I want to use the UV-Tools plugin but I donΒ΄t get it to run on SketchUp 2013 - IΒ΄m certainly
doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
I dontΒ΄t get any icons or any context menu
I appreciate any help -
you could try ThruPaint
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
or SketchUV
http://extensions.sketchup.com/en/content/sketchuv -
Thanks for this awesome plugin Whaat!
I use SketchUV and Roadkill, and it works great.
WrapR is in development and it will make unwraping inside SU.
