    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
      Sketchy Master
      Where Is the URL for download
      • GaieusG
        It's in the first post.
        • P
          pdwyer
          Does this still work with SU8 on windows?
          The plugin doesn't start, no menu is created. 😞
            It works perfectly you must have installed it incorrectly.
            I use it everyday on v7, v7.1 and v8
            • massimoM
              massimo Moderator
              Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
              • P
                pdwyer
                Ignore me, it is working, just not the UI I was expecting πŸ˜„
                all good
                • B
                  burningman
                  I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much.
                  • GaieusG
                    It's attached to the first post with a
                    http://forums.sketchucation.com/images/upload_icons/ruby.gif
                    icon.
                    Generally this is the way authors publish and keep their plugins updated here so always look in the first post.
                    • B
                      burningman
                      BIGthanks mate!
                      • E
                        Eric5150
                        I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
                        Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
                        Eric
                        http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
                        Thanks in advance
                        (would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
                          jumpjack
                          I don't understand how to use the plugin.
                          I installed it,I get the new context menu.
                          I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
                          Nothing happens.
                          • FrederikF
                            Frederik
                            Why would you install a plugin if you don't know what it is...?
                            Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...
                            Try applying a bitmap texture to a sphere or a cylinder...
                            It's important that it's not just a color but a bitmap texture...
                            You'll see that the texture looks odd on such shapes...
                            Now click the sphere to select it...
                            Right-click it an from the submenu select UV tools and then select i.e. spherical...
                            You'll see that the texture looks correct now...
                            Cheers
                            Kim Frederik
                              demigamer
                              Thanks A lot !
                              Downloading. . . . πŸ˜‰
                              • HornOxxH
                                HornOxx
                                Hi All,
                                Since I use Artisan, I have the need to improve my uv-texturing skills ❗
                                I want to use the UV-Tools plugin but I donΒ΄t get it to run on SketchUp 2013 - IΒ΄m certainly
                                doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
                                I dontΒ΄t get any icons or any context menu
                                I appreciate any help
                                never trust a skinny cook
                                • N
                                  numerobis
                                  you could try ThruPaint
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                                  or SketchUV
                                  http://extensions.sketchup.com/en/content/sketchuv
                                  • T
                                    thegoodguy
                                    Thanks for this awesome plugin Whaat!
                                    • N
                                      nlipovac
                                      I use SketchUV and Roadkill, and it works great. πŸ˜„
                                      WrapR is in development and it will make unwraping inside SU.
                                      • 9 / 9
