    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • sadyoS
      sadyo
      Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
      It's happening too with UVTools v0.2 ❓ ❓ ❓ ,
      • sadyoS
        sadyo
        Oops...Sorry 😳 It's working pretty well on SU8 now, when i try to using it with Jeff Hammond Tips
          Sketchy Master
          Where Is the URL for download
          • GaieusG
            It's in the first post.
            • P
              pdwyer
              Does this still work with SU8 on windows?
              The plugin doesn't start, no menu is created. 😞
                It works perfectly you must have installed it incorrectly.
                I use it everyday on v7, v7.1 and v8
                • massimoM
                  massimo Moderator
                  Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
                  • P
                    pdwyer
                    Ignore me, it is working, just not the UI I was expecting 😄
                    all good
                    • B
                      burningman
                      I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much.
                      • GaieusG
                        It's attached to the first post with a
                        http://forums.sketchucation.com/images/upload_icons/ruby.gif
                        icon.
                        Generally this is the way authors publish and keep their plugins updated here so always look in the first post.
                        • B
                          burningman
                          BIGthanks mate!
                          • E
                            Eric5150
                            I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
                            Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
                            Eric
                            http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
                            Thanks in advance
                            (would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
                              jumpjack
                              I don't understand how to use the plugin.
                              I installed it,I get the new context menu.
                              I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
                              Nothing happens.
                              • FrederikF
                                Frederik
                                Why would you install a plugin if you don't know what it is...?
                                Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...
                                Try applying a bitmap texture to a sphere or a cylinder...
                                It's important that it's not just a color but a bitmap texture...
                                You'll see that the texture looks odd on such shapes...
                                Now click the sphere to select it...
                                Right-click it an from the submenu select UV tools and then select i.e. spherical...
                                You'll see that the texture looks correct now...
                                Cheers
                                Kim Frederik
                                  demigamer
                                  Thanks A lot !
                                  Downloading. . . . 😉
                                  • HornOxxH
                                    HornOxx
                                    Hi All,
                                    Since I use Artisan, I have the need to improve my uv-texturing skills ❗
                                    I want to use the UV-Tools plugin but I don´t get it to run on SketchUp 2013 - I´m certainly
                                    doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
                                    I dont´t get any icons or any context menu
                                    I appreciate any help
                                    never trust a skinny cook
                                    • N
                                      numerobis
                                      you could try ThruPaint
                                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                                      or SketchUV
                                      http://extensions.sketchup.com/en/content/sketchuv
                                      • T
                                        thegoodguy
                                        Thanks for this awesome plugin Whaat!
                                        • N
                                          nlipovac
                                          I use SketchUV and Roadkill, and it works great. 😄
                                          WrapR is in development and it will make unwraping inside SU.
                                          • 9 / 9
