    [Tutorial > Modeling] Hidden Seam Tutorial
    19 Posts 14 Posters 9.4k Views 14 Watching
    • boofredlayB
      boofredlay
      Many times I have two or more components that touch but I don't want it to appear that they do. I want a seamless transition but want to keep the geometry separate.
      Here is a quick tutorial I created to show the best way to achieve this result.
      Download Tutorail
      The image below shows the before and after.
      http://www.sketchucation.com/forums/scf/sas/Tutorials/HiddenSeamTutorial.jpg
      • KrisidiousK
        Krisidious
        awesome Boo... thanks for this.
        I run into this issue all the time with windows and doors in walls.
        By: Kristoff Rand
          That's a great tip. I frequently split components that are symmetrical along their centerlines. Then by copying that half or even quarter, mirroring the copy (copies) and hiding the seam lines I get the appearance of a whole without the file bloat. Getting ridd of those un-needed faces helps to hide the seam line. Here's an example
          • GaieusG
            The only problem that unfortunately this won't work with curved surfaces - just like when you hide the lines on the side of a cylinder for instance instead of softening them.
            Still an important thing to remember and use this technique when there are coplanar faces!
            • D
              dylan
              Nice one Eric, I come across this problem a lot.
              http://dmdarchitecture.co.uk/
              • tinanneT
                tinanne
                GREAT TIP! I also have this problem, thanks Boo!
                Executive Director : American Society of Architectural Illustrators
                AIP 30 Competition opens soon. ASAI.org
                Architectural Rendering
                • boofredlayB
                  boofredlay
                  I am happy to hear this has helped so many.
                  • EdsonE
                    Edson
                    great answer to a problem that is not complex but very annoying.
                    by the way, your signature reminds me of indian chiefs depicted in westerns with names that were descriptive of some of their main traits of personality (like "one who rises with the sun" and the like).
                    regards.
                    http://www.mahfuz.arq.br
                    • boofredlayB
                      boofredlay
                      That is beautiful Dave!
                      • M
                        mateo soletic
                        Thank a lot Boo, great stuff.
                        Concept Illustrations
                          Thank you. πŸ˜‰
                            I did this one last night for a friend. Thought I'd post it as another example of this method.
                            http://img.photobucket.com/albums/v506/weekender410/th_CribRail.jpg
                            • Jean LemireJ
                              Jean Lemire
                              Hi folks.
                              Good stuff Boofredlay.
                              If, for any reason, you want to retain the offending internal face that is showing trough the sides, you may hide it instead of deleting it.
                              Just ideas.
                              • GaieusG
                                Good tip, Jean, John has also been thinking like you just one post above:
                                http://www.sketchucation.com/forums/scf/viewtopic.php?p=23347#p23347
                                • B
                                  bcoleman001
                                  Great Tips! Thanks!
                                  • JClementsJ
                                    JClements
                                    Great tip.
                                    I've been using this method for a while. However, I can never be sure (anticipate) if I'll need those surfaces later if a change to the model is needed. So I create My Hidden Edges and/or My Hidden Surfaces layers and then turn their visibility off and move the geometry to them (I try not to use the "hide" function). At end of modeling, getting rid of the hidden faces is as easy as deleting My Hidden Surfaces layer.
                                    • A
                                      arcaterra
                                      HI
                                      I just tried to download the tutorial from your link, but I get an error that the page does not exist.
                                      Can you check?
                                      • boofredlayB
                                        boofredlay
                                        Fixed.
                                        • J
                                          Julius
                                          very useful tip!
