    [Tutorial > Modeling] Hidden Seam Tutorial
    19 Posts 14 Posters 9.2k Views 14 Watching
    • boofredlayB
      boofredlay
      That is beautiful Dave!
        mateo soletic
        Thank a lot Boo, great stuff.
        Concept Illustrations
          Thank you. πŸ˜‰
            I did this one last night for a friend. Thought I'd post it as another example of this method.
            http://img.photobucket.com/albums/v506/weekender410/th_CribRail.jpg
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              Good stuff Boofredlay.
              If, for any reason, you want to retain the offending internal face that is showing trough the sides, you may hide it instead of deleting it.
              Just ideas.
              • GaieusG
                Good tip, Jean, John has also been thinking like you just one post above:
                http://www.sketchucation.com/forums/scf/viewtopic.php?p=23347#p23347
                • B
                  bcoleman001
                  Great Tips! Thanks!
                  • JClementsJ
                    JClements
                    Great tip.
                    I've been using this method for a while. However, I can never be sure (anticipate) if I'll need those surfaces later if a change to the model is needed. So I create My Hidden Edges and/or My Hidden Surfaces layers and then turn their visibility off and move the geometry to them (I try not to use the "hide" function). At end of modeling, getting rid of the hidden faces is as easy as deleting My Hidden Surfaces layer.
                      arcaterra
                      HI
                      I just tried to download the tutorial from your link, but I get an error that the page does not exist.
                      Can you check?
                      • boofredlayB
                        boofredlay
                        Fixed.
                          Julius
                          very useful tip!
