    [Tutorial > Modeling] Hidden Seam Tutorial
    19 Posts 14 Posters 9.2k Views 14 Watching
      That's a great tip. I frequently split components that are symmetrical along their centerlines. Then by copying that half or even quarter, mirroring the copy (copies) and hiding the seam lines I get the appearance of a whole without the file bloat. Getting ridd of those un-needed faces helps to hide the seam line. Here's an example
        The only problem that unfortunately this won't work with curved surfaces - just like when you hide the lines on the side of a cylinder for instance instead of softening them.
        Still an important thing to remember and use this technique when there are coplanar faces!
          dylan
          Nice one Eric, I come across this problem a lot.
          http://dmdarchitecture.co.uk/
          • tinanneT Offline
            tinanne
            GREAT TIP! I also have this problem, thanks Boo!
            Executive Director : American Society of Architectural Illustrators
            AIP 30 Competition opens soon. ASAI.org
            Architectural Rendering
            • boofredlayB Offline
              boofredlay
              I am happy to hear this has helped so many.
              • EdsonE Offline
                Edson
                great answer to a problem that is not complex but very annoying.
                by the way, your signature reminds me of indian chiefs depicted in westerns with names that were descriptive of some of their main traits of personality (like "one who rises with the sun" and the like).
                regards.
                http://www.mahfuz.arq.br
                  boofredlay
                  That is beautiful Dave!
                    mateo soletic
                    Thank a lot Boo, great stuff.
                    Concept Illustrations
                      Thank you. πŸ˜‰
                        I did this one last night for a friend. Thought I'd post it as another example of this method.
                        http://img.photobucket.com/albums/v506/weekender410/th_CribRail.jpg
                        • Jean LemireJ Offline
                          Jean Lemire
                          Hi folks.
                          Good stuff Boofredlay.
                          If, for any reason, you want to retain the offending internal face that is showing trough the sides, you may hide it instead of deleting it.
                          Just ideas.
                            Good tip, Jean, John has also been thinking like you just one post above:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?p=23347#p23347
                              bcoleman001
                              Great Tips! Thanks!
                              • JClementsJ Offline
                                JClements
                                Great tip.
                                I've been using this method for a while. However, I can never be sure (anticipate) if I'll need those surfaces later if a change to the model is needed. So I create My Hidden Edges and/or My Hidden Surfaces layers and then turn their visibility off and move the geometry to them (I try not to use the "hide" function). At end of modeling, getting rid of the hidden faces is as easy as deleting My Hidden Surfaces layer.
                                  arcaterra
                                  HI
                                  I just tried to download the tutorial from your link, but I get an error that the page does not exist.
                                  Can you check?
                                    boofredlay
                                    Fixed.
                                      Julius
                                      very useful tip!
