    [Tutorial > Modeling] Hidden Seam Tutorial
    19 Posts 14 Posters 9.4k Views 14 Watching
    • KrisidiousK
      Krisidious
      awesome Boo... thanks for this.
      I run into this issue all the time with windows and doors in walls.
      By: Kristoff Rand
        That's a great tip. I frequently split components that are symmetrical along their centerlines. Then by copying that half or even quarter, mirroring the copy (copies) and hiding the seam lines I get the appearance of a whole without the file bloat. Getting ridd of those un-needed faces helps to hide the seam line. Here's an example
        • GaieusG
          The only problem that unfortunately this won't work with curved surfaces - just like when you hide the lines on the side of a cylinder for instance instead of softening them.
          Still an important thing to remember and use this technique when there are coplanar faces!
            dylan
            Nice one Eric, I come across this problem a lot.
            http://dmdarchitecture.co.uk/
            • tinanneT
              tinanne
              GREAT TIP! I also have this problem, thanks Boo!
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
              • boofredlayB
                boofredlay
                I am happy to hear this has helped so many.
                • EdsonE
                  Edson
                  great answer to a problem that is not complex but very annoying.
                  by the way, your signature reminds me of indian chiefs depicted in westerns with names that were descriptive of some of their main traits of personality (like "one who rises with the sun" and the like).
                  regards.
                  http://www.mahfuz.arq.br
                  • boofredlayB
                    boofredlay
                    That is beautiful Dave!
                      mateo soletic
                      Thank a lot Boo, great stuff.
                      Concept Illustrations
                        Thank you. πŸ˜‰
                          I did this one last night for a friend. Thought I'd post it as another example of this method.
                          http://img.photobucket.com/albums/v506/weekender410/th_CribRail.jpg
                          • Jean LemireJ
                            Jean Lemire
                            Hi folks.
                            Good stuff Boofredlay.
                            If, for any reason, you want to retain the offending internal face that is showing trough the sides, you may hide it instead of deleting it.
                            Just ideas.
                            • GaieusG
                              Good tip, Jean, John has also been thinking like you just one post above:
                              http://www.sketchucation.com/forums/scf/viewtopic.php?p=23347#p23347
                              • B
                                bcoleman001
                                Great Tips! Thanks!
                                • JClementsJ
                                  JClements
                                  Great tip.
                                  I've been using this method for a while. However, I can never be sure (anticipate) if I'll need those surfaces later if a change to the model is needed. So I create My Hidden Edges and/or My Hidden Surfaces layers and then turn their visibility off and move the geometry to them (I try not to use the "hide" function). At end of modeling, getting rid of the hidden faces is as easy as deleting My Hidden Surfaces layer.
                                    arcaterra
                                    HI
                                    I just tried to download the tutorial from your link, but I get an error that the page does not exist.
                                    Can you check?
                                    • boofredlayB
                                      boofredlay
                                      Fixed.
                                        Julius
                                        very useful tip!
