    Overhead Line Shaft Detail
    44 Posts 12 Posters 8.0k Views 12 Watching
      Combining parts I've modeled based on a variety of sources from the late 1800s to very early 1900s. Still need the belt shifter if I can find the details.
      https://live.staticflickr.com/65535/52348897737_1b249d5871.jpg
      AO in Kerkythea under a faces only and a sketchy edges hidden line export.
        I wish you would share larger images 👍
        The level of detail is srumptious. I just want to see it closer and more of it... 😢
          Thank you Rich. I'll see if I can make a larger version of this for you.
            Here you go Rich.
            Full size:
            https://live.staticflickr.com/65535/52350411795_849ee41c77_o.png
            With a wireframe overlay.
            https://live.staticflickr.com/65535/52350229668_e679c1e656_o.png
            • tuna1957T Offline
              tuna1957
              Absolutely brilliant modeling 👍 👍 Side note I recall seeing pictures where workers would use a wooden stick to pop the belts off and on the pulleys….
                Thank you sir.
                Yes. There should be a sort of fork with a long wooden handle to shift the belt back and forth between fast and loose pulleys. I have yet to find dimensioned drawings or even really good photos of the belt shifter.
                  db11
                  Really cool Dave.
                  I've enjoyed seeing the evolution of your vintage lathe model and look forward to seeing it hooked up to your newly-modelled line shaft!
                  Makes me think of the Hancock Shaker Village shop:
                  (beautiful vintage shop and great video of this type of system in action for those who aren't familiar)
                  • HornOxxH Offline
                    HornOxx
                    @rich o brien said:
                    I wish you would share larger images 👍 ...
                    also for me please !!! 😄
                    And again a beautiful work which shows that accurate work and details pay off! 👍
                    never trust a skinny cook
                      db11
                      Dave — it's not a dimensioned drawing or even a photo, but at 2:45 in the video linked above there's a good shot of the belt shifter you describe shifting between the two pulleys. (and again at around 4:00 showing the shift of power to the bandsaw)
                      Maybe you could contact them for good stills of the mechanism(s)? (Perhaps they also have drawings?)
                      Just a thought.
                        Thanks Doug. I'll look.
                        Hornoxx and Rich, if you click on the last two images you should see the full size version of them. And thank you!
                          Another very fine piece. Cracking result. 👊
                          • Bryan KB Offline
                            Always great work! 👍
                              Very nice work Dave 👍 there is something particularly appealing to me about that model.
                                @l i am said:
                                ...there is something particularly appealing to me about that model.
                                It's bananas!
                                  Thank you gentlemen.
                                    Here's a detail showing some of the screw threads. Added some color in the render.
                                    https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
                                    • tuna1957T Offline
                                      tuna1957
                                      The detail in your mechanical models just slays me 👍 👍
                                        Thank you sir. Maybe it makes up for my lack of skill with rendering that you have. 😉
                                          The best renders are the ones that convey the right amount of details.
                                          This is one of those renders where you appreciate the accuracy and level of modelling involved.
                                          Not one where errors are disguised using texture maps etc
                                          Cannot wait for you to animate it 😛
                                          • tuna1957T Offline
                                            tuna1957
                                            Dave your rendering skills are more than “just fine”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                                            • 1 / 3
