    2.2k Posts 487 Posters 936.0k Views 492 Watching
      TIG Moderator @junphuc17945
      @junphuc17945
      Can't you login and manage your licenses yourself ?
      https://sketchucation.com/webshop/my-licences.php
      J 1 Reply Last reply Reply Quote 0
      • P Offline
        PMsarto
        Hi Fredo,
        I need assistance regarding the ClothWorks plugin license management.
        A few years ago, I purchased a perpetual license for ClothWorks, allowing activation on up to 3 computers (seats). Unfortunately, one of the computers that had an active license has been formatted and disposed of. As a result, I am unable to release the license from that machine.
        Could you please guide me on how to remotely release the license from the computer that is no longer in use? This would enable me to activate the plugin on my new laptop.
        Thank you very much for your help.
        Best
        Giuseppe
          Rich O Brien Moderator @PMsarto
          @PMsarto said in SCFLicense: Extension Licensing on Sketchucation:
          Send an email to support@sketchucation.com
          • H Offline
            hoverteamph Newcomers
            How can I release this license without check box? Do I have an option where I can force release this kinds of license? Please help thankyou .
              Rich O Brien Moderator @hoverteamph
              @hoverteamph Update Sketchucation Tools on the devices missing the checkbox to 4.4.1
              Sketchucation Tools | SketchUcation
              (sketchucation.com)
                aagcmis Newcomers
                How do I edit? Pls
                  ameerproxy @TIG
                  @TIG
                  I tried as per the instructions Thanks Let me try one more time ,
                    ameerproxy @TIG
                    @TIG
                    Hi I tried the methods you mention , but its showing the same Error As license Expired
                      Rich O Brien Moderator @ameerproxy
                      @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                        ameerproxy @ameerproxy
                        @ameerproxy ![alt text](Licence file history.jpg image url)
                        Sorry i cant understand what the solution to make it possible
                          @ameerproxy
                          Please run this command
                          A 2 Replies Last reply Reply Quote 0
                            ameerproxy @Rich O Brien
                            @Rich-O-Brien yes i run that
                                @ameerproxy You have yet to run it because it generate the following.
                                  Rich O Brien Moderator @Rich O Brien
                                  @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
                                  Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
                                  Select the text in the Ruby Console and copy it. Then paste that into your reply.
                                  You have omitted vital information.
                                  A 1 Reply Last reply Reply Quote 0
                                    @Rich-O-Brien sorry here we go
                                    Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                    • Sketchup: 22.0.354
                                    • LibFredo6: v14.5b
                                    • LibFredo6 Binary loaded
                                    • Sketchucation ExtensionStore: 4.4.1
                                    • SCFLicense: v6.4a - 74
                                    • Fredo6 Plugins
                                      Curviloft v2.0a
                                      Curvizard v2.5a
                                      FredoCorner v2.7a
                                      FredoScale v3.6a
                                      RoundCorner v3.4a
                                      ThruPaint v2.4a
                                      ToolsOnSurface v2.6a
                                      VisuHole v1.5a
                                    • SCFLicense directory present
                                      Signature File: 2023-01-01 14:57:22 +0400
                                      Curvizard: 2023-03-15 18:36:09 +0400
                                      ToolsOnSurface: 2023-01-03 20:07:48 +0400
                                      @ameerproxy
                                      • Close SketchUp
                                      • Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                                      • Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                      • Start SketchUp
                                      Retrieve your license files from https://sketchucation.com/webshop/my-licences.php and save them locally on your device
                                      In SketchUp go to Tools > FredoCollection > FredoScale > License...
                                      Activate FredoScale using your Fredoscale license file
                                      Screenshot any Error messages
                                        @Rich-O-Brien Perfect , Thanks for the quick support , so same for other plugins to re validate the license
                                        Fredo6 Plugins Information on 2024-06-28 17:01:10 +0400
                                        • LibFredo6: v14.5b
                                        • Fredo6 Plugins
                                          Curviloft v2.0a
                                          Curvizard v2.5a
                                          FredoCorner v2.7a
                                          FredoScale v3.6a - licensed FULL
                                          RoundCorner v3.4a
                                          ThruPaint v2.4a
                                          VisuHole v1.5a
                                          Signature File: 2024-06-28 17:00:27 +0400
                                          FredoScale: 2024-06-28 17:00:33 +0400
                                          Is Fredoscale working as expected?
                                          If yes, please repeat the steps using the appropriate license to activate other extensions
                                            cro13
                                            h
                                            I have problems releasing the available seats of the license I purchased for Round Corner, I reinstalled Windows and I cannot use the licenses on my computers with the new system
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 109
                                            • 110
                                            • 94 / 110
