    2.3k Posts 515 Posters 2.5m Views 520 Watching
      Rich O Brien Moderator @ameerproxy
      @ameerproxy
      Please run this command
      A 2 Replies Last reply
        ameerproxy @Rich O Brien
        @Rich-O-Brien yes i run that
            @ameerproxy You have yet to run it because it generate the following.
              Rich O Brien Moderator @Rich O Brien
              @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
              Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
              Select the text in the Ruby Console and copy it. Then paste that into your reply.
              You have omitted vital information.
              A 1 Reply Last reply
                @Rich-O-Brien sorry here we go
                Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                • Platform: x64-mswin64_140 - Ruby: 2.7.2
                • Sketchup: 22.0.354
                • LibFredo6: v14.5b
                • LibFredo6 Binary loaded
                • Sketchucation ExtensionStore: 4.4.1
                • SCFLicense: v6.4a - 74
                • Fredo6 Plugins
                  Curviloft v2.0a
                  Curvizard v2.5a
                  FredoCorner v2.7a
                  FredoScale v3.6a
                  RoundCorner v3.4a
                  ThruPaint v2.4a
                  ToolsOnSurface v2.6a
                  VisuHole v1.5a
                  Signature File: 2023-01-01 14:57:22 +0400
                  Curvizard: 2023-03-15 18:36:09 +0400
                  ToolsOnSurface: 2023-01-03 20:07:48 +0400
                  @ameerproxy
                  • Close SketchUp
                  • Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                  • Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                  • Start SketchUp
                  Retrieve your license files from https://sketchucation.com/webshop/my-licences.php and save them locally on your device
                  In SketchUp go to Tools > FredoCollection > FredoScale > License...
                  Activate FredoScale using your Fredoscale license file
                  Screenshot any Error messages
                    @Rich-O-Brien Perfect , Thanks for the quick support , so same for other plugins to re validate the license
                    Fredo6 Plugins Information on 2024-06-28 17:01:10 +0400
                    • LibFredo6: v14.5b
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      Curvizard v2.5a
                      FredoCorner v2.7a
                      FredoScale v3.6a - licensed FULL
                      RoundCorner v3.4a
                      ThruPaint v2.4a
                      VisuHole v1.5a
                      Signature File: 2024-06-28 17:00:27 +0400
                      FredoScale: 2024-06-28 17:00:33 +0400
                      @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                      Is Fredoscale working as expected?
                      If yes, please repeat the steps using the appropriate license to activate other extensions
                      • C
                        cro13
                        h
                        I have problems releasing the available seats of the license I purchased for Round Corner, I reinstalled Windows and I cannot use the licenses on my computers with the new system
                        • B
                          brittico Newcomers
                          Can't validate Fredo Portrait License
                          Hello please need help, just purchased the license but it doesnt work, have read all the help solutions but nothing works. It says "sorry an error occured in the communication with sketchucation. I have internet, all is work. please help, this extension is vital for my work
                            Rich O Brien Moderator @brittico
                            @brittico said in SCFLicense: Extension Licensing on Sketchucation:
                            This can be the result of a strict network policy. Please whitelist:
                            *.sketchucation.com
                            Our try switching to a less strict network.
                            • B
                              brittico Newcomers
                              Hi, thanks for reply, how to whiteliste? the network is my own private one.
                              TIGT 1 Reply Last reply
                                TIG Moderator @brittico
                                @brittico
                                Your Firewall has a list of sites it prevents access to - a 'blacklist'.
                                There is a 'whitelist' of sites that are allowed.
                                Manage your Firewall and add *.sketchucation.com to that...
                                B 1 Reply Last reply
                                • B
                                  brittico Newcomers
                                  I am on microsoft defener, is it a file, folder, file type or process, sorry for the dump questions but I am not a pro on the pc, thanks
                                  • B
                                    brittico Newcomers @TIG
                                    @TIG have whitelisted it as a "file type", also switched of defender, tried it again, and again, no luck, have the same problem with "round corner" which was already working as I bought the license back in march.
                                    TIGT Rich O BrienR 2 Replies Last reply
                                      @brittico
                                      Are there other options like 'url' ?
                                      The string given is not a file-type...
                                        @brittico
                                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                        B 2 Replies Last reply
                                        • B
                                          brittico Newcomers @Rich O Brien
                                          @Rich-O-Brien Fredo6 Plugins Information on 2024-07-06 16:50:40 +0100
                                          • Sketchup: 24.0.553
                                          • LibFredo6: v14.5c
                                          • Fredo6 Plugins
                                            Curviloft v1.9b
                                            FredoPortrait v2.9a
                                            RoundCorner v3.4a
                                            Signature File: 2024-07-04 16:41:09 +0100
                                            RoundCorner: 2024-03-04 10:02:47 +0000
                                          • B
                                            @Rich-O-Brien I have just found out none of my Fredo Extensions are working anymore, Curvy Loft and Round Corner are Extensions which I was already working with as I bought the license but now none of them are working, they are all telling me that I need to get a license and when trying to activate I get the same message for all three extensions.
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
