    2.3k Posts 515 Posters 2.8m Views 520 Watching
      TIG Moderator @ju_marq
      @ju_marq
      I assume you have saved your license files to some subfolder on your computer - e.g. ../Documents/Licenses
      That's not sufficient to complete the action.
      It is spelled out in the help links above...
      Start SketchUp and under the Tools menu find the Fredo6 Collection item, look for your extensions.
      Find the section about License...
      In the dialog choose 'Activate License' and find the license file on your computer...
      Your screenshot shows you are almost there...
      You need to be connected to the Internet to do this.
      Click the Activate License button and navigate to your license file saved onto your computer.
      Note that FredoCorner and RoundCorner are different extensions and need to have their own license on your computer and Activated...
      Occasionally users confuse the two extensions and do not actually have a valid license file available...
      J 1 Reply Last reply
        junphuc17945 @TIG
        @TIG hi TIG
        Can you help me release this stuck licenses:
        Seat ID: 27971; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
        Seat ID: 27982; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
        Thank you !
        TIGT 1 Reply Last reply
          TIG Moderator @junphuc17945
          @junphuc17945
          Can't you login and manage your licenses yourself ?
          https://sketchucation.com/webshop/my-licences.php
          • P
            PMsarto
            Hi Fredo,
            I need assistance regarding the ClothWorks plugin license management.
            A few years ago, I purchased a perpetual license for ClothWorks, allowing activation on up to 3 computers (seats). Unfortunately, one of the computers that had an active license has been formatted and disposed of. As a result, I am unable to release the license from that machine.
            Could you please guide me on how to remotely release the license from the computer that is no longer in use? This would enable me to activate the plugin on my new laptop.
            Thank you very much for your help.
            Best
            Giuseppe
              Rich O Brien Moderator @PMsarto
              @PMsarto said in SCFLicense: Extension Licensing on Sketchucation:
              Send an email to support@sketchucation.com
              • H
                hoverteamph Newcomers
                How can I release this license without check box? Do I have an option where I can force release this kinds of license? Please help thankyou .
                  Rich O Brien Moderator @hoverteamph
                  @hoverteamph Update Sketchucation Tools on the devices missing the checkbox to 4.4.1
                  Sketchucation Tools | SketchUcation
                  (sketchucation.com)
                    aagcmis Newcomers
                    How do I edit? Pls
                      ameerproxy @TIG
                      @TIG
                      I tried as per the instructions Thanks Let me try one more time ,
                        ameerproxy @TIG
                        @TIG
                        Hi I tried the methods you mention , but its showing the same Error As license Expired
                          Rich O Brien Moderator @ameerproxy
                          @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                            ameerproxy @ameerproxy
                            @ameerproxy ![alt text](Licence file history.jpg image url)
                            Sorry i cant understand what the solution to make it possible
                              @ameerproxy
                              Please run this command
                              A 2 Replies Last reply
                                ameerproxy @Rich O Brien
                                @Rich-O-Brien yes i run that
                                    @ameerproxy You have yet to run it because it generate the following.
                                      Rich O Brien Moderator @Rich O Brien
                                      @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
                                      Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
                                      Select the text in the Ruby Console and copy it. Then paste that into your reply.
                                      You have omitted vital information.
                                      A 1 Reply Last reply
                                        @Rich-O-Brien sorry here we go
                                        Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                                        • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                        • Sketchup: 22.0.354
                                        • LibFredo6: v14.5b
                                        • LibFredo6 Binary loaded
                                        • Sketchucation ExtensionStore: 4.4.1
                                        • SCFLicense: v6.4a - 74
                                        • Fredo6 Plugins
                                          Curviloft v2.0a
                                          Curvizard v2.5a
                                          FredoCorner v2.7a
                                          FredoScale v3.6a
                                          RoundCorner v3.4a
                                          ThruPaint v2.4a
                                          ToolsOnSurface v2.6a
                                          VisuHole v1.5a
                                          Signature File: 2023-01-01 14:57:22 +0400
                                          Curvizard: 2023-03-15 18:36:09 +0400
                                          ToolsOnSurface: 2023-01-03 20:07:48 +0400
                                          @ameerproxy
                                          • Close SketchUp
                                          • Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                                          • Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                          • Start SketchUp
                                          Retrieve your license files from https://sketchucation.com/webshop/my-licences.php and save them locally on your device
                                          In SketchUp go to Tools > FredoCollection > FredoScale > License...
                                          Activate FredoScale using your Fredoscale license file
                                          Screenshot any Error messages
                                            @Rich-O-Brien Perfect , Thanks for the quick support , so same for other plugins to re validate the license
                                            Fredo6 Plugins Information on 2024-06-28 17:01:10 +0400
                                            • LibFredo6: v14.5b
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              Curvizard v2.5a
                                              FredoCorner v2.7a
                                              FredoScale v3.6a - licensed FULL
                                              RoundCorner v3.4a
                                              ThruPaint v2.4a
                                              VisuHole v1.5a
                                              Signature File: 2024-06-28 17:00:27 +0400
                                              FredoScale: 2024-06-28 17:00:33 +0400
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
