    2.3k Posts 515 Posters 2.8m Views 520 Watching
    • F
      Fifo_78 @TIG
      @TIG
      Hi TIG,
      Thanks for your reply. I've read the help pages but don't understand them very well. The manner discribed in it, seem not be function in my case or may be I'm just gaz man 😜
      The SketUcation is v4.41, the Libfredo6 is v14.5b, SCFLicense is V6.4 -74, SCFLicense directory : present, Signature File : absent?!.
      What could I do??
      Best regards.
        ameerproxy
        Hi i have the unlimited licence for fredo6 bundle , but now its showing this error i choose the the same licence file while i click on the activate licence ,
        please solve this issue
        TIGT A 2 Replies Last reply
        • F
          Fifo_78
          @TIG
          I've found in Tools the famour Fedo6 Collection and then I've activate the plugins I've downloaded. There're now actived.
          Thanks for all.
          Fifo.
            TIG Moderator @ameerproxy
            @ameerproxy
            Have you downloaded/installed the latest versions of all of those bundled Fredo6 extensions, and LibFredo6 and the SketchUcation tools [for the latest licensing set up].
            You also need to restart SketchUp to sync everything.
            The license files you got for the bundled set need to be stored somewhere safe on your computer - e.g. in a special subfolder made in your Documents folder. You then need to 'validate' each of them individually for each of Fredo6's extensions in the appropriate submenus under the Tools menu.
              ju_marq
              Hello. I bought the RoundCorner Perpetual License, I installed FredoCorner_v2.7a, LibFredo6_v14.5b, RoundCorner_v3.4a, SketchUcationTools_v4.4.1 and LibFredo6_v14.5a.
              I also downloaded SCF_Purchased_License_RoundCorner_NORMAL_20230615.scflicense
              but it is not working.
              Please help!!!
              Captura de tela 2024-06-11 175237.png Captura de tela 2024-06-11 175304.png Captura de tela 2024-06-11 175314.png
              TIGT 1 Reply Last reply
                TIG Moderator @ju_marq
                @ju_marq
                I assume you have saved your license files to some subfolder on your computer - e.g. ../Documents/Licenses
                That's not sufficient to complete the action.
                It is spelled out in the help links above...
                Start SketchUp and under the Tools menu find the Fredo6 Collection item, look for your extensions.
                Find the section about License...
                In the dialog choose 'Activate License' and find the license file on your computer...
                Your screenshot shows you are almost there...
                You need to be connected to the Internet to do this.
                Click the Activate License button and navigate to your license file saved onto your computer.
                Note that FredoCorner and RoundCorner are different extensions and need to have their own license on your computer and Activated...
                Occasionally users confuse the two extensions and do not actually have a valid license file available...
                J 1 Reply Last reply
                  junphuc17945 @TIG
                  @TIG hi TIG
                  Can you help me release this stuck licenses:
                  Seat ID: 27971; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
                  Seat ID: 27982; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
                  Thank you !
                    TIG Moderator @junphuc17945
                    @junphuc17945
                    Can't you login and manage your licenses yourself ?
                    https://sketchucation.com/webshop/my-licences.php
                    • P
                      PMsarto
                      Hi Fredo,
                      I need assistance regarding the ClothWorks plugin license management.
                      A few years ago, I purchased a perpetual license for ClothWorks, allowing activation on up to 3 computers (seats). Unfortunately, one of the computers that had an active license has been formatted and disposed of. As a result, I am unable to release the license from that machine.
                      Could you please guide me on how to remotely release the license from the computer that is no longer in use? This would enable me to activate the plugin on my new laptop.
                      Thank you very much for your help.
                      Best
                      Giuseppe
                        Rich O Brien Moderator @PMsarto
                        @PMsarto said in SCFLicense: Extension Licensing on Sketchucation:
                        Send an email to support@sketchucation.com
                        • H
                          hoverteamph Newcomers
                          How can I release this license without check box? Do I have an option where I can force release this kinds of license? Please help thankyou .
                            Rich O Brien Moderator @hoverteamph
                            @hoverteamph Update Sketchucation Tools on the devices missing the checkbox to 4.4.1
                            Sketchucation Tools | SketchUcation
                            (sketchucation.com)
                              aagcmis Newcomers
                              How do I edit? Pls
                                ameerproxy @TIG
                                @TIG
                                I tried as per the instructions Thanks Let me try one more time ,
                                  ameerproxy @TIG
                                  @TIG
                                  Hi I tried the methods you mention , but its showing the same Error As license Expired
                                    Rich O Brien Moderator @ameerproxy
                                    @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                      ameerproxy @ameerproxy
                                      @ameerproxy ![alt text](Licence file history.jpg image url)
                                      Sorry i cant understand what the solution to make it possible
                                        @ameerproxy
                                        Please run this command
                                          ameerproxy @Rich O Brien
                                          @Rich-O-Brien yes i run that
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
