    2.3k Posts 515 Posters 2.3m Views 520 Watching
      Rich O Brien Moderator @ameerproxy
      @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
      Hi I tried the methods you mention , but its showing the same Error As license Expired
      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        ameerproxy @ameerproxy
        @ameerproxy ![alt text](Licence file history.jpg image url)
        Sorry i cant understand what the solution to make it possible
          @ameerproxy
          Please run this command
          A 2 Replies Last reply Reply Quote 0
            ameerproxy @Rich O Brien
            @Rich-O-Brien yes i run that
                @ameerproxy You have yet to run it because it generate the following.
                  Rich O Brien Moderator @Rich O Brien
                  @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
                  Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
                  Select the text in the Ruby Console and copy it. Then paste that into your reply.
                  You have omitted vital information.
                  A 1 Reply Last reply Reply Quote 0
                    @Rich-O-Brien sorry here we go
                    Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                    • Sketchup: 22.0.354
                    • LibFredo6: v14.5b
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      Curvizard v2.5a
                      FredoCorner v2.7a
                      FredoScale v3.6a
                      RoundCorner v3.4a
                      ThruPaint v2.4a
                      ToolsOnSurface v2.6a
                      VisuHole v1.5a
                      Signature File: 2023-01-01 14:57:22 +0400
                      Curvizard: 2023-03-15 18:36:09 +0400
                      ToolsOnSurface: 2023-01-03 20:07:48 +0400
                      @ameerproxy
                      • Close SketchUp
                      • Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                      • Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                      • Start SketchUp
                      Retrieve your license files from https://sketchucation.com/webshop/my-licences.php and save them locally on your device
                      In SketchUp go to Tools > FredoCollection > FredoScale > License...
                      Activate FredoScale using your Fredoscale license file
                      Screenshot any Error messages
                        @Rich-O-Brien Perfect , Thanks for the quick support , so same for other plugins to re validate the license
                        Fredo6 Plugins Information on 2024-06-28 17:01:10 +0400
                        • LibFredo6: v14.5b
                        • Fredo6 Plugins
                          Curviloft v2.0a
                          Curvizard v2.5a
                          FredoCorner v2.7a
                          FredoScale v3.6a - licensed FULL
                          RoundCorner v3.4a
                          ThruPaint v2.4a
                          VisuHole v1.5a
                          Signature File: 2024-06-28 17:00:27 +0400
                          FredoScale: 2024-06-28 17:00:33 +0400
                          Is Fredoscale working as expected?
                          If yes, please repeat the steps using the appropriate license to activate other extensions
                            cro13
                            h
                            I have problems releasing the available seats of the license I purchased for Round Corner, I reinstalled Windows and I cannot use the licenses on my computers with the new system
                              brittico Newcomers
                              Can't validate Fredo Portrait License
                              Hello please need help, just purchased the license but it doesnt work, have read all the help solutions but nothing works. It says "sorry an error occured in the communication with sketchucation. I have internet, all is work. please help, this extension is vital for my work
                                Rich O Brien Moderator @brittico
                                @brittico said in SCFLicense: Extension Licensing on Sketchucation:
                                This can be the result of a strict network policy. Please whitelist:
                                *.sketchucation.com
                                Our try switching to a less strict network.
                                  brittico Newcomers
                                  Hi, thanks for reply, how to whiteliste? the network is my own private one.
                                  TIGT 1 Reply Last reply Reply Quote 0
                                    TIG Moderator @brittico
                                    @brittico
                                    Your Firewall has a list of sites it prevents access to - a 'blacklist'.
                                    There is a 'whitelist' of sites that are allowed.
                                    Manage your Firewall and add *.sketchucation.com to that...
                                    B 1 Reply Last reply Reply Quote 1
                                      brittico Newcomers
                                      I am on microsoft defener, is it a file, folder, file type or process, sorry for the dump questions but I am not a pro on the pc, thanks
                                        brittico Newcomers @TIG
                                        @TIG have whitelisted it as a "file type", also switched of defender, tried it again, and again, no luck, have the same problem with "round corner" which was already working as I bought the license back in march.
                                        TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
                                          @brittico
                                          Are there other options like 'url' ?
                                          The string given is not a file-type...
                                            @brittico
                                            B 2 Replies Last reply Reply Quote 0
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
