    2.2k Posts 498 Posters 1.0m Views 503 Watching
    • Rich O BrienR Online
      Rich O Brien Moderator @mandraget
      @mandraget said in SCFLicense: Extension Licensing on Sketchucation:
      hi fredo can you help me releasing my round corner license because there no option to release it from web, i need it asap, thank you
      Update extensions on all these devices to enable online releasing.
      Most important is to update Sketchucation Tools.
      M 1 Reply Last reply Reply Quote 0
        Rich O Brien Moderator @nguyenhung269
        @nguyenhung269
        Please update Sketchucation Tools on all these devices
        K 1 Reply Last reply Reply Quote 0
          mandraget @Rich O Brien
          but i cannot access there device right now, that my office device, and my office on day off till friday
          • P Offline
            ppappa0099 Newcomers @Rich O Brien
            @Rich-O-Brien
            Plugin: JointPushPull (v7.1a - 74) on SketchUp 2023
            Issue: Persistent License Validation Errors (A04 $\rightarrow$ B03) after correcting computer name.
            Hello SCF Support Team,
            I'm stuck in a license loop after changing my computer name, which triggered ERROR_A04.
            I have tried the following steps multiple times:
            1.Deleted Signature File: Erased SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt to force revalidation.
            2.Activation Failed (B03): Upon trying to "Activate License", I immediately receive ERROR_B03 (connection failure to server).
            3.Network Check: I confirmed I have a stable internet connection and temporarily disabled Windows Defender Firewall (Public/Private). The B03 error still persists.
            Since the system cannot connect to complete the revalidation, I'm stuck "Not Licensed".
            Could you please provide a manual method or an alternative solution to bypass the online connection for revalidation?
            Thank you!
              Rich O Brien Moderator @ppappa0099
              @ppappa0099
              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
              • P Offline
                @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
                Fredo6 Plugins Information on 2025-11-19 01:27:43 +0800
                • Platform: x64-mswin64_140 - Ruby: 2.7.2
                • Sketchup: 23.0.397
                • LibFredo6: v15.5a
                • LibFredo6 Binary loaded
                • Sketchucation ExtensionStore: 5.0.3
                • SCFLicense: v7.1a - 74
                • Fredo6 Plugins
                  Curviloft v2.0a
                  JointPushPull v4.8a
                • SCFLicense directory present
                  Signature File: 2025-11-19 01:01:49 +0800
                  @ppappa0099 Is your device named with non-alphanumeric characters?
                  Please don't delete posts that have info we need to help.
                  Error B03 is related the non-alphanumeric characters
                    As well as your computer-name, your windows-username shouldn't contain any non-ASCII characters.
                    Because these can trip up Ruby code processes...
                    Also you do need to restart your computer after the renaming...
                    • K Offline
                      Kondybas @Rich O Brien
                      @nguyenhung269
                      I have the same problem.
                      Old notebook was formatted and donated to the ukrainian army. Sure licenses were not released before. Now I have licenses that cannot be revoked via the web page.
                        Rich O Brien Moderator @Kondybas
                        @Kondybas
                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on your current device and copy/paste the output into your reply.
                        • K Offline
                          Kondybas
                          Fredo6 Plugins Information on 2025-11-18 20:59:03 +0200
                          • Platform: x64-mingw32 - Ruby: 2.2.4
                          • Sketchup: 17.2.2555
                          • LibFredo6: v15.5a
                          • Sketchucation ExtensionStore: 4.3.1
                          • SCFLicense: v6.1a - 72
                          • Fredo6 Plugins
                            Curviloft v2.0a
                            Curvizard v2.5a
                            FredoScale v3.6a
                            JointPushPull v4.9a
                            RoundCorner v3.4a
                            ToolsOnSurface v2.6a
                            Signature File: 2025-11-18 19:44:48 +0200
                            @Kondybas Please update Sketchucation Tools to v 5.0.3
                            Sketchucation Tools | SketchUcation
                            (sketchucation.com)
                            Restart SketchUp
                            After restart run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output
                            Latest Sketchucation Tools enables online releasing.
                            • K Offline
                              Kondybas
                              I have that pane not responding to clicks
                                Ah....SketchUp 2017.
                                Please Install this version
                                SketchUcationTools_v4.4.1.rbz
                                • K Offline
                                  Kondybas
                                  Have installed 4.4.1 and still no checkboxes for license revokation
                                  Also there are no button images and bottom buttons in SUTools 4.4.1 (4.3.1 has the same issue for a while)
                                    Check https://sketchucation.com/webshop/my-licences.php now
                                    1 Reply Last reply 😳 Reply Quote 0
                                    • K Offline
                                      Kondybas
                                      WOW!
                                      I promise I'll be VERY careful with licenses now!
                                      Am I got it right that SUTools 5.0.3 is not compatible with SU2017?
                                        @Kondybas
                                        Correct, but we'll take a look and see what we can do to make it work.
                                        • K Offline
                                          Kondybas
                                          Thank you very much for all the efforts, SketchUp is the only CAD I really love since version 6.
                                          1 Reply Last reply πŸ‘ Reply Quote 2
                                          • E Offline
                                            ethansatsky Newcomers
                                            Im activating my Toposhaper liscense, but when I select the .scflience liscense, I get a message saying: error in liscense validation. repsonse from sketchucation liscense is not in the database
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 108 / 113
