    Flowify problems
    extensions
    70 Posts 25 Posters 46.8k Views 25 Watching
      MrKrabs
      is there any way to make it suitable?
      • F Offline
        francesgale
        hello, first time using flowify, any idea what i should do with this error?
          SMatta79
          Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
          Seamless+pattern+--+Cells.skp flowify test.skp
            I can help you if files are in format skp 6 to 2017 ๐Ÿ˜„
              SMatta79
              Hi Pilou, No unfortunately mine is a 2022 version ๐Ÿ˜ž How else can we do this?
                I suppose that you have choice when you make an exportation...(save as)
                  Meanwhile back in 2022... ๐Ÿ˜›
                  The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
                  • N Offline
                    n hong
                    Hi, i'm currently having trouble with Flowify.
                    I'm trying to place wall studs on a curvature wall but this input error keeps popping up.
                    I'll appreciate it if someone could help.
                    INPUT ERROR
                    • tuna1957T Offline
                      tuna1957
                      n hong, Flowify might not be the best tool for what you want to do. Iโ€™m not a Flowify expert but my tests end up distorting the shape of the wall studs. Your might be better off using something like โ€œCopy Along Curveโ€ by Anton S.
                        mingjawaz
                        Can someone help me to solve this flowify problem. Why i cant use the flowify even i have followed the steps of group things
                        ๐Ÿ˜ž
                        Sketchup 2020
                          The projection plane is either an empty rectangular face or a flat custom made quad grid with the same topology as the target surface.
                          Your target mesh is not Quad Grid.
                          https://i.imgur.com/5ohQlT1.png
                          You've some work to do
                            meerhumzakhan Newcomers
                            HELP!!!! I have done following steps and got the error in the end.
                            1=group
                            2=group
                            3=group
                            1+2+3=group (let's call it "X")
                            imposed grid=Ok
                            4=group
                            4+X=group
                            ====> flowify====> not enough input error
                              The source and target need same topology and the support should be aligned as shown above
                                I lied...
                                ...you can go like this too
                                So something in your setup is not right. Could be nesting order or topology...
                                • panixiaP Offline
                                  panixia
                                  @Rich The text in your example is pure genius ๐Ÿคฃ
                                    I believe it's not 4 + X = group
                                    but 4 + X = Select! ๐Ÿ˜‰
                                    Then call Flowify! ๐Ÿค“
                                      RemsRivera123 Newcomers
                                      Hey everyone!
                                      Iโ€™m having some trouble with Flowify and hoping someone can help me out. Iโ€™ve set up my groups as follows:
                                      A โ€“ The curve
                                      B โ€“ The length of the curve
                                      C โ€“ The pathway
                                      D โ€“ The group I want to flow
                                      But when I select everything and try to apply Flowify, it doesnโ€™t actually "flow"โ€”instead, it just resizes to a much bigger scale. Any idea what might be going wrong?
                                      Thanks in advance! Appreciate any help!
                                      PS. I attached a video showing my problem
                                      SKP Flowify Problem.mp4
                                        Can you share a file? @RemsRivera123
                                        Itโ€™s quicker solve if thereโ€™s something to see
                                        R 1 Reply Last reply Reply Quote 0
                                          RemsRivera123 Newcomers @Rich O Brien
                                          @Rich-O-Brien Hello there, here's the skp file
                                          Staircase 01.skp
                                            IDK if my reply is pushing through @Rich-O-Brien but I did send a reply with the skp file attached
                                            • 3 / 4
