    SketchUcation Tools in 2017
    113 Posts 17 Posters 10.0k Views 17 Watching
    • BoxB Offline
      Nice one Tig, although I don't need it.
      • N Offline
        NickW
        Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
          So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
          Can someone else confirm this works for them too, so I can make an update...
          • JQLJ Offline
            JQL
            Here it is Tig:
            www.casca.pt
            Visit us on facebook!
            • josephkim626J Offline
              josephkim626
              TIG,
              Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
              I have test those behaviors and reporting to you:
              The window is resize-able with some minimum restrictions
              The last used height is remembered on restart as well as the width.
              I think it is good to be updated as 3.0.3 version.
                Thanks for all of your responses...
                I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                • N Offline
                  NickW
                  Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                  • N Offline
                    NickW
                    But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                      that's Fredo's Update Checker. Just close it.
                      • PixeroP Offline
                        Pixero
                        3.0.3 Worked for me.
                        But I'd like to be able to make the window higher. I have a highres screen...
                          I set the maximum height arbitrarily at 900px.
                          What do you think a reasonable maximum might be ?
                          I can always adjust the code...
                          • PixeroP Offline
                            Pixero
                            My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                              OK, I'll discuss it with Rich...
                              • ntxdaveN Offline
                                ntxdave
                                TIG, Rich - Thanks so much for the update. I am now running fine. 😎
                                Just got to go through and install all of my plugins in 2017 now.
                                TIG - The size if fine for my laptop.
                                Press F1...thank me later
                                  josephkim626
                                  Version still showing as 3.0.2 on store, but 3.0.3 on manager.
                                    v3.0.4 now includes dialog height fix for Pixero and and a secondary fix for additional folder dialog popup
                                    Thanks guys for helping us fix this so quickly
                                    • JQLJ Offline
                                      JQL
                                      I got a 4k and it's 3840x2160 there are 5k and more.
                                      In reality I don't know of a reason why the limit should exist (besides the hack of course). Why not put it at 3000px or more?
                                      www.casca.pt
                                        The ExtensionStore³ dialog's max height is currently set to be 1600px.
                                        If anyone has a very good reason to make it bigger, then please state your case...
                                        But, no promises...
                                        • PixeroP Offline
                                          Pixero
                                          @JQL: Wouldn't the scroll bar be very small for users with a lower screen resolution then?
                                          • JQLJ Offline
                                            JQL
                                            But you can shrink the window right? We are talking about a max size but all elements inside will be fixed scale. Just the scroll area changes. Why do we need a minimu max size?
                                            www.casca.pt
                                            • 6
                                            • 5 / 6
