    SketchUcation Tools in 2017
    113 Posts 17 Posters 18.4k Views 17 Watching
    • N
      NickW
      But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
        that's Fredo's Update Checker. Just close it.
        • PixeroP
          Pixero
          3.0.3 Worked for me.
          But I'd like to be able to make the window higher. I have a highres screen...
            I set the maximum height arbitrarily at 900px.
            What do you think a reasonable maximum might be ?
            I can always adjust the code...
            • PixeroP
              Pixero
              My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                OK, I'll discuss it with Rich...
                • ntxdaveN
                  ntxdave
                  TIG, Rich - Thanks so much for the update. I am now running fine. ๐Ÿ˜Ž
                  Just got to go through and install all of my plugins in 2017 now.
                  TIG - The size if fine for my laptop.
                  Press F1...thank me later
                  • josephkim626J
                    josephkim626
                    Version still showing as 3.0.2 on store, but 3.0.3 on manager.
                      v3.0.4 now includes dialog height fix for Pixero and and a secondary fix for additional folder dialog popup
                      Thanks guys for helping us fix this so quickly
                      • JQLJ
                        JQL
                        I got a 4k and it's 3840x2160 there are 5k and more.
                        In reality I don't know of a reason why the limit should exist (besides the hack of course). Why not put it at 3000px or more?
                        www.casca.pt
                        Visit us on facebook!
                          The ExtensionStoreยณ dialog's max height is currently set to be 1600px.
                          If anyone has a very good reason to make it bigger, then please state your case...
                          But, no promises...
                          • PixeroP
                            Pixero
                            @JQL: Wouldn't the scroll bar be very small for users with a lower screen resolution then?
                            • JQLJ
                              JQL
                              But you can shrink the window right? We are talking about a max size but all elements inside will be fixed scale. Just the scroll area changes. Why do we need a minimu max size?
                              www.casca.pt
                              • FrederikF
                                Frederik
                                3.0.4 works fine for me as well... ๐Ÿ˜„
                                Thanks for the fix... ๐Ÿ‘
                                Cheers
                                Kim Frederik
                                  To recap.
                                  In pre-2017 versions there was no max/min dialog size set up, and it worked fine for all users.
                                  In the initial-2017 version there was no max/min size set up and it also worked fine for most users - however, for an as yet inexplicable reason, a few users found that the dialog always opened fixed at 37px high [just the top bar], with no vertical resizing possible ar all.
                                  I then tried various fixes... and eventually found that giving the dialog a min height then at least made it visible, BUT it would still not resize vertically.
                                  I then found that adding a max height allowed it to be resized vertically, and that those changes were also remembered across session in the Registry.
                                  After some debate the max height was set at 1600px, as it seems a reasonable size for most monitors.
                                  That's v3.0.4...
                                  If a significantly bigger height is needed please state your case...
                                  • JQLJ
                                    JQL
                                    I have no need to make it any bigger. Just mindless discussing things that are not worth the trouble.
                                    Thanks for all your trouble Tig!
                                    www.casca.pt
                                      Discussion is good. We are looking at v4 to address the common complaints v3 raised. Especially the dialog resizing since no one really knew it refactored at larger sizes.
                                      v4 get rid of that idea and simplifies the UI to make it more obvious what is what....we hope
                                      Click image to play...
                                      • ntxdaveN
                                        ntxdave
                                        Rich that looks really good to me.
                                        On another topic, what is the status of EDG3D?
                                        • JQLJ
                                          JQL
                                          @rich o brien said:
                                          Discussion is good.
                                          I like that version. I don't like the bottom menu on v3 and this seems to be out. Splitting commands from up and bottom is not nice, especially as SCF tools has little functions.[/quote]
                                          I hope V4 can be expanded horizontally to be wider than v3 as that top categories list is really cool but I don't like having to click the arrows to view all categories. I'd rather have that even if the tool would fill my screen as I'm never doing anything else when using it and I like full access to functionality at any moment.
                                          V3 looked probably better, but v4 seems to be better.
                                          www.casca.pt
                                            It can be fluid width or fixed.
                                            Fluid spans the dialog and if you resize it just keeps filling. Focus is to make it obvious from the beginning what everything does and why.
                                            • 5 / 6
