    [Tutorial] Animator Quick Start
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    136 Posts 39 Posters 808.9k Views 40 Watching
    • jujuJ Offline
      juju
      @saumil12345 said:
      Greetings,
      Thank you for a quick reply.
      Check out this turn table animation I created using animator , v-ray for rendering and some post production.
      Saumil Upadhyay on Instagram: "Ten X (Part 1) - Dynamic Sports Centre. It has moving components that adjust according to situation & adapts to the function. #architecture #sportscentre #turntable #model #physical #digitalart #aftereffects #premierepro #disintegration #thanos #snap #shatter #art #artistsoninstagram #quarantinecontent #vfx #vray #lumion #animation #woodworking"
      167 likes, 17 comments - saumil.1 on May 5, 2020: "Ten X (Part 1) - Dynamic Sports Centre. It has moving components that adjust according to situation & adapts to the function. #architecture #sportscentre #turntable #model #physical #digitalart #aftereffects #premierepro #disintegration #thanos #snap #shatter #art #artistsoninstagram #quarantinecontent #vfx #vray #lumion #animation #woodworking".
      Instagram (www.instagram.com)
      OR
      Page Not Found
      Web word processing, presentations and spreadsheets
      (drive.google.com)
      nice one, loved the finger snap with accompanying disintegration at the end
        Saumil12345
        Greetings,
        Can anyone suggest quick rendering plugin(other than V-ray) for basic rendering of the animation. It has nearly 2000 frames.
        • ntxdaveN Offline
          ntxdave
          Have you looked at Twilight Render? Animator also supports it.
          Press F1...thank me later
            Saumil12345
            Not yet, I'll go through it.
            Thank you
              Saumil12345
              Greetings,
              I have been trying to render my animation using sketchFX. In the progress bar & even in the sketchup it shows that frames are being generated , but when it is done I don't get the full video or all the frames generated, I only get 2-3 frames out of 300 frames in my folder.
              See attached images
                Saumil12345
                Can we add safe frame in animator?
                Or is there any way I can get an idea of how much area will be covered if I export in 1:1 aspect ratio while setting up the camera.
                  aweardon
                  How do I save the video I create?
                    smai31
                    Bonjour Fredo,
                    J'adore ton plugin et je souhaiterai l'utiliser pour visualiser et rejouer la trajectoire de drones ou robots dans une pièce.
                    Je m'explique, les robots sont équipés de capteurs qui me communiquent toutes les secondes leur position X,Y,Z + ID. Pourrait-on imaginer lire ce fichier et écrire en automatique le script de toutes les séquences d'une seconde (ou X secondes) de chacune des translation des différents drones ?
                    En clair, peut-on créer un code pour générer un script en automatique et l'ajouter au modèle pour qu'il puisse être accessible à l'ouverture d'Animator, visualiser les mouvements et réaliser les films des séquences de ces mouvements ...
                    Merci d'avance de ton éclairage sur la faisabilité de cette idée
                    Bien à toi
                    Stéphane
                    • fredo6F Offline
                      fredo6
                      @smai31
                      J'ai prévu de faire des animations par script, mais ca prendra un peu de temps avant que je me remettes aux évolutions d'Animator
                      Pour l'instant, on peut faire l'inverse et visualiser les trajectoires sous forme de courbes de points choisis sur des objets animés.
                      Fredo
                      • F Offline
                        Frankoi
                        I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
                        Could someone help me?
                        • F Offline
                          Frankoi
                          Bonjour,
                          Je reposte le message en fançais si besoin, suite à l'installation de fredolib et de animator sur mon mac avec sketchuppro 2017, je ne vois que la toolbar avec 4 boutons, mais pas tout l'environnement de travail.
                          Quelqu'un peux-t-il me répondre sur ce sujets?
                          Merci bcp
                            smai31
                            Merci pour cet excellent conseil !
                            Bien à toi
                            Stéphane
                            • fredo6F Offline
                              fredo6
                              What happens if you click on the first button of the toolbar.
                              If nothing happens, the redo the same, but with the Ruby console opened, so that you can see if there are error messages.
                                sketchnut
                                Animator does not start when pressing the clip Icon.
                                Using skethup 2020.
                                • fredo6F Offline
                                  fredo6
                                  Using skethup 2020.
                                  Can you open the Ruby console and check if there are error messages.
                                    lts9876 Newcomers
                                    I like the videos; they help a lot. I am not sure if this is the place to ask this question. I installed animator. I used it a couple days. Know when I click on the clip editor. It will not open. I am not sure what to do.
                                    • fredo6F Offline
                                      fredo6
                                      Could you migrate to LibFredo6 v13.6a. It should solve the problem.
                                        lts9876 Newcomers
                                        Thank you that worked!
                                        • SJS66S Offline
                                          SJS66
                                          Hi all, I've been doing some Animator training, making a tip truck reverse, tip up then down, then drive away. I've managed to get it to reverse & tip up...although the hydraulic tipper ram doesn't extend right. I used a combination of rotate, follow path & layer visibility to make it extend.
                                          I made a video of it so you can see the results so far.
                                          Any suggestions on how to improve most welcome.
                                          Cheers.
                                          • SJS66S Offline
                                            SJS66
                                            Well, I isolated the tip truck hydraulic ram to make things easier to see & replicated the movement for it as if emptying the truck's load (tipping) but I'd like to see if it could be made to extend whilst it is rotating instead of rotating then extending like I've got it to do.
                                            Here's the latest video link.
                                            • 6
                                            • 7
                                            • 6 / 7
