    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 899.0k Views 40 Watching
    • C
      ctrlaltf1
      Hello! I'm trying to animate a scene using STATIC SCENE (the ones created in SKP).
      Here is the prob.
      I add Scene 1, Scene 2, Scene 3....
      and it ALWAYS forces a transition between them.
      Whereas I want:
      Scene 1. ...5 secs.
      CUT to SCENE 2..... 5 secs.
      CUT to SCENE 3.... 5 secs.
      NO TRANSITIONS between scenes.
      I'm getting a bald spot looking for a solution :S
      Any comments appreciated.
      • jujuJ
        juju
        Here is the prob.
        Whereas I want:
        Scene 1. ...5 secs.
        Page Utilities 2
        • fredo6F
          When you click on each element for scenes in the timeline, you have a dialog box appearing in the corner.
          Just click and disable the 'Fade out' (it's a toggle button)
          • fredo6F
            Hi, Is it possible to reuse the animated object in another sketchup file?
            Not possible at the moment.
            I am trying to think whether it could be possible and how to do it, but not obvious.
            • fredo6F
              I did an APPARITION in animator to create a section cut effect of a particular object. However, after rendering, the section cut effect affected the whole scene instead of that object.
              This is one known problem with rendering software. They don't seem to take section cuts into account.
              Could you try to render a model with an active section cut using Ambient Occlusion Ex and tell me if you see it.
              fredo
              • fredo6F
                Ambient occlusion does not render section cut correction when export via animation mode.
                Section cut does work in Ambient occlusion in a static view.
                Animator interacts with Ambient Occlusion Ex via an API. Maybe it caches the state of objects. Let me see if there is a way to force a refresh. I noticed the same behavior with Thea.
                  Saumil12345
                  I have a question regarding explosion effect in animator, is there a way to control direction of elements that explodes, currently they are exploding in all the directions but i cannot control them as in which element should move in which direction.
                  This plug-in is super useful, thanks for making something that can convert your imaginations into something visual.
                  Regards,
                  Saumil
                  • fredo6F
                    Currently Animator explodes away from the center of gravity of the object. There is unfortunately no way to customize it at the moment.
                      Saumil12345
                      Greetings,
                      Thank you for a quick reply.
                      Check out this turn table animation I created using animator , v-ray for rendering and some post production.
                      Saumil Upadhyay on Instagram: "Ten X (Part 1) - Dynamic Sports Centre. It has moving components that adjust according to situation & adapts to the function. #architecture #sportscentre #turntable #model #physical #digitalart #aftereffects #premierepro #disintegration #thanos #snap #shatter #art #artistsoninstagram #quarantinecontent #vfx #vray #lumion #animation #woodworking"
                      Ten X (Part 1) - Dynamic Sports Centre. It has moving components that adjust according to situation & adapts to the function. #architecture #sportscentre #turntable #model #physical #digitalart #aftereffects #premierepro #disintegration #thanos #snap #shatter #art #artistsoninstagram #quarantinecontent #vfx #vray #lumion #animation #woodworking - @saumil.1 on May 5, 2020
                      Instagram (www.instagram.com)
                      OR
                      Page Not Found
                      Web word processing, presentations and spreadsheets
                      (drive.google.com)
                      • jujuJ
                        juju
                        @saumil12345 said:
                        Greetings,
                        OR
                        Page Not Found
                        (drive.google.com)
                        nice one, loved the finger snap with accompanying disintegration at the end
                          Saumil12345
                          Greetings,
                          Can anyone suggest quick rendering plugin(other than V-ray) for basic rendering of the animation. It has nearly 2000 frames.
                          • ntxdaveN
                            ntxdave
                            Have you looked at Twilight Render? Animator also supports it.
                            Press F1...thank me later
                              Saumil12345
                              Not yet, I'll go through it.
                              Thank you
                                Saumil12345
                                Greetings,
                                I have been trying to render my animation using sketchFX. In the progress bar & even in the sketchup it shows that frames are being generated , but when it is done I don't get the full video or all the frames generated, I only get 2-3 frames out of 300 frames in my folder.
                                See attached images
                                  Saumil12345
                                  Can we add safe frame in animator?
                                  Or is there any way I can get an idea of how much area will be covered if I export in 1:1 aspect ratio while setting up the camera.
                                    aweardon
                                    How do I save the video I create?
                                      smai31
                                      Bonjour Fredo,
                                      J'adore ton plugin et je souhaiterai l'utiliser pour visualiser et rejouer la trajectoire de drones ou robots dans une pièce.
                                      Je m'explique, les robots sont équipés de capteurs qui me communiquent toutes les secondes leur position X,Y,Z + ID. Pourrait-on imaginer lire ce fichier et écrire en automatique le script de toutes les séquences d'une seconde (ou X secondes) de chacune des translation des différents drones ?
                                      En clair, peut-on créer un code pour générer un script en automatique et l'ajouter au modèle pour qu'il puisse être accessible à l'ouverture d'Animator, visualiser les mouvements et réaliser les films des séquences de ces mouvements ...
                                      Merci d'avance de ton éclairage sur la faisabilité de cette idée
                                      Bien à toi
                                      Stéphane
                                      • fredo6F
                                        @smai31
                                        J'ai prévu de faire des animations par script, mais ca prendra un peu de temps avant que je me remettes aux évolutions d'Animator
                                        Pour l'instant, on peut faire l'inverse et visualiser les trajectoires sous forme de courbes de points choisis sur des objets animés.
                                        • F
                                          Frankoi
                                          I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
                                          Could someone help me?
                                          • F
                                            Frankoi
                                            Bonjour,
                                            Je reposte le message en fançais si besoin, suite à l'installation de fredolib et de animator sur mon mac avec sketchuppro 2017, je ne vois que la toolbar avec 4 boutons, mais pas tout l'environnement de travail.
                                            Quelqu'un peux-t-il me répondre sur ce sujets?
                                            Merci bcp
                                            • 6 / 7
