    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • BoxB Offline
      Errm, that would be a white whale. But then you norgies eat whale. So maybe it's a lightly grilled whale.
      ...I'm off now to pickle a koala for my breakfast.
        You know, I started modelling that car so many years ago - in 3dsmax. It's starting to become a haunting ghost. At some point I need to defeat this thing. My bluewhite whale.
          Cursed, I even quickly googled it and picked the first answer.
          • Z Offline
            ZahariStoyanov
            Got me dead 🀣
              • HornOxxH Offline
                HornOxx
                Rich, this is just awesome πŸ‘ ❗ πŸ‘
                This is a great vehicle - This tank design look more nice than threatening. Great details - does one chain link(?) consist out of 2 single parts?
                never trust a skinny cook
                  So... when will we see the animated version...? πŸ˜„
                  • pbacotP Offline
                    "Sick" as the kiddies say. Is that a turret? Do the tubes upfront stretch if it turns?
                    • N Offline
                      nlipovac
                      This tank looks made for new toy design, shoots soap balloons. πŸ˜„
                      • ontaottoO Offline
                        ontaotto
                        @cotty said:
                        Another simple one...
                        [attachment=0:1su2j5k6]<!-- ia0 -->2pipes.jpg<!-- ia0 -->[/attachment:1su2j5k6]
                        I have done in the past some similar shapes, to me the best shape to get those T Pipes are the hexagons:
                        https://lh3.googleusercontent.com/GN3AwVZp-TozAfcTf7BfTuFBhVtuXP1iyVVXokQjA6mPIeGhvmq_JXg_-pP20kvaIgDuklLBk1dp_w=w1920-h1080-no
                        https://lh3.googleusercontent.com/-O6lTySKOAlM/WEbm6k4VBaI/AAAAAAAAB4U/KB2TxAF6pOImUO0SzMBeDcAeFx0R5-eTACL0B/w530-d-h479-p/T%2BTube%2B3D%2BMesh%2BCorrected.png
                        https://lh3.googleusercontent.com/-ihtGxqGDFHg/WEbm_aqnCkI/AAAAAAAAB4w/CVNAlgiWrkYf4oNX-dSEqV88dxKI28G8QCL0B/w530-d-h528-p/T%2BTube%2B3D%2BModel.png
                        This sample was done in another program, but works exactly the same in SU by using SubD.
                        Cheers!
                        Twitter: @ontaotto
                          Those are octagons, right?
                          • ontaottoO Offline
                            ontaotto
                            Dang! Yeah you're right, in this particular case were used octagons, but in the main shapes when you want to get rounded ones, the hexagon should work good.
                            Twitter: @ontaotto
                              Do you generally feel hexagons works better than octagons or any other ngons?
                              • ontaottoO Offline
                                ontaotto
                                When you are working with simple tubes, the hexagon seems to me as the best, this is another sample:
                                https://lh3.googleusercontent.com/-A8MwVNRwKSw/WEctywRmQiI/AAAAAAAAB6E/et8wue-v8gM7CjqvN3PNUkO_hopCM6qCQCL0B/w530-d-h321-p/Carrara%2BSubD.png
                                It's a simple hexagon based shape and when you repeat it you can create a texture, as many shown here, the best thing is that you can UV map those very well:
                                https://lh3.googleusercontent.com/-F3c0pcs0YEk/WEcuKtwBsrI/AAAAAAAAB60/JvcrEzR2oG8hJGXZNSo-cNcSgHXbACPBwCL0B/w530-d-h427-p/3D%2BModel%2BCarrara.png
                                Twitter: @ontaotto
                                  Lovely example!
                                  Btw, what software is that? Do you know if it uses OpenSubdiv?
                                  • panixiaP Offline
                                    panixia
                                    not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
                                    looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
                                    so definetly, it depends on the shape/topology you are tryng to achieve.
                                      • JQLJ Offline
                                        JQL
                                        Have you seen this Thomthom?
                                        Introduction to Microdisplacements β€” Blender Guru
                                        This is one of the most exciting developmentsΒ to come to Blender inΒ recent years. It's two separate features that work together: Adaptive Subdivision - Automatically subdivides objects based on the amount of screen space they take up Micropolygon displacement - Uses t
                                        Blender Guru (www.blenderguru.com)
                                        www.casca.pt
                                        Visit us on facebook!
                                        • N Offline
                                          nlipovac
                                          Hi Rich, when will be seeing SU_to_wRapr_to_Substance tutorials?
                                          Great modeling.
                                          • ontaottoO Offline
                                            ontaotto
                                            @thomthom said:
                                            Lovely example!
                                            Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
                                            Twitter: @ontaotto
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 82
                                            • 83
                                            • 36 / 83
