    Modelling a tramway
    595 Posts 43 Posters 449.2k Views 40 Watching
      I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
      Using ProfileBuilder 3 in SketchUp to draw train rails
      • jo-keJ
        jo-ke
        I need a path in the middle and two rails (special profile) left and right, to follow the path.
        http://www.zz7.de
        • jo-keJ
          jo-ke
          next project
          photo:
          SU:
          Render:
          http://www.zz7.de
          Reply Quote 2
            Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
              Rich O Brien Moderator @jo-ke
              With Curviloft the profiles can be offset from the path...
              Profile offset from Path using CurviLoft
              That does mean you need to do each side as a separate operation.
              Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
              TIG's Extrusion Tools would do it too similar to CurviLofts approach.
              • jo-keJ
                jo-ke
                the newer version of profile builder seems to be a good tool.
                Is it possible to insert an own profile?
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    http://www.zz7.de
                    Reply Quote 3
                      Wunderbar.
                        Sorry, I missed your query.
                        Yes, you can create a library of custom profiles.
                        • majidM
                          majid
                          These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                          jo-keJ 1 Reply Last reply
                          • jo-keJ
                            jo-ke @majid
                            @majid It is just AI. Gemini does a great job
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              we sold some old trams to Oberbozen Italy.
                              this is how it could look like:
                              http://www.zz7.de
                              Reply Quote 3
                              • jo-keJ
                                jo-ke
                                new model.
                                I've found that picture of an old tram of my hometown:
                                took it to meshyAI and remodelled it:
                                then I merged the picture with an old one of our shop in the 60ties:
                                result was great:
                                http://www.zz7.de
                                Reply Quote 3
                                • jo-keJ
                                  jo-ke
                                  another perspective:
                                  http://www.zz7.de
                                    Did you photoshop in the posters on the front?
                                    • jo-keJ
                                      jo-ke @jo-ke
                                      yes, gemini destroyed some of the letters.
                                      the original before PS:
                                      http://www.zz7.de
                                      Reply Quote 3
                                        The 'proper job', no error.
                                        • jo-keJ
                                          jo-ke
                                          old GDR impressions.
                                          http://www.zz7.de
                                          Reply Quote 2
                                            Brilliant.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
