    Modelling a tramway
    587 Posts 43 Posters 406.7k Views 42 Watching
    • jo-keJ
      jo-ke
      next project
      photo:
      SU:
      Render:
      http://www.zz7.de
      Reply Quote 2
        Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
          Rich O Brien Moderator @jo-ke
          @jo-ke said:
          I need a path in the middle and two rails (special profile) left and right, to follow the path.
          With Curviloft the profiles can be offset from the path...
          Profile offset from Path using CurviLoft
          That does mean you need to do each side as a separate operation.
          Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
          TIG's Extrusion Tools would do it too similar to CurviLofts approach.
          • jo-keJ
            jo-ke
            the newer version of profile builder seems to be a good tool.
            Is it possible to insert an own profile?
            http://www.zz7.de
            • jo-keJ
              jo-ke
              http://www.zz7.de
              • jo-keJ
                jo-ke
                http://www.zz7.de
                Reply Quote 3
                  Wunderbar.
                    Sorry, I missed your query.
                    Yes, you can create a library of custom profiles.
                    • majidM
                      majid
                      These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                      jo-keJ 1 Reply Last reply
                      • jo-keJ
                        jo-ke @majid
                        @majid It is just AI. Gemini does a great job
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          we sold some old trams to Oberbozen Italy.
                          this is how it could look like:
                          http://www.zz7.de
                          Reply Quote 3
                          • jo-keJ
                            jo-ke
                            new model.
                            I've found that picture of an old tram of my hometown:
                            took it to meshyAI and remodelled it:
                            then I merged the picture with an old one of our shop in the 60ties:
                            result was great:
                            http://www.zz7.de
                            Reply Quote 3
                            • jo-keJ
                              jo-ke
                              another perspective:
                              http://www.zz7.de
                                Did you photoshop in the posters on the front?
                                • jo-keJ
                                  jo-ke @jo-ke
                                  yes, gemini destroyed some of the letters.
                                  the original before PS:
                                  http://www.zz7.de
                                  Reply Quote 3
                                    The 'proper job', no error.
                                    • jo-keJ
                                      jo-ke
                                      old GDR impressions.
                                      http://www.zz7.de
                                      Reply Quote 2
                                        Brilliant.
                                        • jo-keJ
                                          jo-ke
                                          West Germany in the year 1950
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            West Germany in 1950
                                            http://www.zz7.de
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
