    Modelling a tramway
    595 Posts 43 Posters 449.3k Views 40 Watching
      Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
        Rich O Brien Moderator @jo-ke
        @jo-ke said:
        I need a path in the middle and two rails (special profile) left and right, to follow the path.
        With Curviloft the profiles can be offset from the path...
        Profile offset from Path using CurviLoft
        That does mean you need to do each side as a separate operation.
        Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
        TIG's Extrusion Tools would do it too similar to CurviLofts approach.
        • jo-keJ
          jo-ke
          the newer version of profile builder seems to be a good tool.
          Is it possible to insert an own profile?
          http://www.zz7.de
          • jo-keJ
            jo-ke
            http://www.zz7.de
            • jo-keJ
              jo-ke
              http://www.zz7.de
              Reply Quote 3
                Wunderbar.
                  Sorry, I missed your query.
                  Yes, you can create a library of custom profiles.
                  • majidM
                    majid
                    These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                    jo-keJ 1 Reply Last reply
                    • jo-keJ
                      jo-ke @majid
                      @majid It is just AI. Gemini does a great job
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        we sold some old trams to Oberbozen Italy.
                        this is how it could look like:
                        http://www.zz7.de
                        Reply Quote 3
                        • jo-keJ
                          jo-ke
                          new model.
                          I've found that picture of an old tram of my hometown:
                          took it to meshyAI and remodelled it:
                          then I merged the picture with an old one of our shop in the 60ties:
                          result was great:
                          http://www.zz7.de
                          Reply Quote 3
                          • jo-keJ
                            jo-ke
                            another perspective:
                            http://www.zz7.de
                              Did you photoshop in the posters on the front?
                              • jo-keJ
                                jo-ke @jo-ke
                                yes, gemini destroyed some of the letters.
                                the original before PS:
                                http://www.zz7.de
                                Reply Quote 3
                                  The 'proper job', no error.
                                  • jo-keJ
                                    jo-ke
                                    old GDR impressions.
                                    http://www.zz7.de
                                    Reply Quote 2
                                      Brilliant.
                                      • jo-keJ
                                        jo-ke
                                        West Germany in the year 1950
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          West Germany in 1950
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            http://www.zz7.de
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
