    Modelling a tramway
    587 Posts 43 Posters 406.7k Views 42 Watching
    • jo-keJ
      jo-ke
      I need a path in the middle and two rails (special profile) left and right, to follow the path.
      http://www.zz7.de
      • jo-keJ
        jo-ke
        next project
        photo:
        SU:
        Render:
        http://www.zz7.de
        Reply Quote 2
          Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
            Rich O Brien Moderator @jo-ke
            With Curviloft the profiles can be offset from the path...
            Profile offset from Path using CurviLoft
            That does mean you need to do each side as a separate operation.
            Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
            TIG's Extrusion Tools would do it too similar to CurviLofts approach.
            • jo-keJ
              jo-ke
              the newer version of profile builder seems to be a good tool.
              Is it possible to insert an own profile?
              http://www.zz7.de
              • jo-keJ
                jo-ke
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  http://www.zz7.de
                  Reply Quote 3
                    Wunderbar.
                      Sorry, I missed your query.
                      Yes, you can create a library of custom profiles.
                      • majidM
                        majid
                        These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                        jo-keJ 1 Reply Last reply
                        • jo-keJ
                          jo-ke @majid
                          @majid It is just AI. Gemini does a great job
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            we sold some old trams to Oberbozen Italy.
                            this is how it could look like:
                            http://www.zz7.de
                            Reply Quote 3
                            • jo-keJ
                              jo-ke
                              new model.
                              I've found that picture of an old tram of my hometown:
                              took it to meshyAI and remodelled it:
                              then I merged the picture with an old one of our shop in the 60ties:
                              result was great:
                              http://www.zz7.de
                              Reply Quote 3
                              • jo-keJ
                                jo-ke
                                another perspective:
                                http://www.zz7.de
                                  Did you photoshop in the posters on the front?
                                  • jo-keJ
                                    jo-ke @jo-ke
                                    yes, gemini destroyed some of the letters.
                                    the original before PS:
                                    http://www.zz7.de
                                    Reply Quote 3
                                      The 'proper job', no error.
                                      • jo-keJ
                                        jo-ke
                                        old GDR impressions.
                                        http://www.zz7.de
                                        Reply Quote 2
                                          Brilliant.
                                          • jo-keJ
                                            jo-ke
                                            West Germany in the year 1950
                                            http://www.zz7.de
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
