    Modelling a tramway
    577 Posts 43 Posters 376.7k Views 41 Watching
    • jo-keJ Offline
      jo-ke
      is there a Pugin to draw rails along path?
      http://www.zz7.de
        ProfileBuillder would be a good option.
        Or CurviLoft
        CurviLoft to make profiles follow a curve in SketchUp
        • jo-keJ Offline
          jo-ke
          I am using profile builder 1 but there is no option for rails
          http://www.zz7.de
            I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
            Using ProfileBuilder 3 in SketchUp to draw train rails
            • jo-keJ Offline
              jo-ke
              I need a path in the middle and two rails (special profile) left and right, to follow the path.
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                next project
                photo:
                SU:
                Render:
                http://www.zz7.de
                  Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                    Rich O Brien Moderator @jo-ke
                    With Curviloft the profiles can be offset from the path...
                    Profile offset from Path using CurviLoft
                    That does mean you need to do each side as a separate operation.
                    Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                    TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                    • jo-keJ Offline
                      jo-ke
                      the newer version of profile builder seems to be a good tool.
                      Is it possible to insert an own profile?
                      http://www.zz7.de
                      • jo-keJ Offline
                        jo-ke
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          http://www.zz7.de
                            Wunderbar.
                              Sorry, I missed your query.
                              Yes, you can create a library of custom profiles.
                              • majidM Offline
                                majid
                                These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                                jo-keJ 1 Reply Last reply Reply Quote 0
                                • jo-keJ Offline
                                  jo-ke @majid
                                  @majid It is just AI. Gemini does a great job
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    we sold some old trams to Oberbozen Italy.
                                    this is how it could look like:
                                    http://www.zz7.de
                                    • jo-keJ Offline
                                      jo-ke
                                      new model.
                                      I've found that picture of an old tram of my hometown:
                                      took it to meshyAI and remodelled it:
                                      then I merged the picture with an old one of our shop in the 60ties:
                                      result was great:
                                      http://www.zz7.de
                                      • jo-keJ Offline
                                        jo-ke
                                        another perspective:
                                        http://www.zz7.de
                                        jo-keJ 1 Reply Last reply Reply Quote 1
                                          Did you photoshop in the posters on the front?
                                          • jo-keJ Offline
                                            jo-ke @jo-ke
                                            yes, gemini destroyed some of the letters.
                                            the original before PS:
                                            http://www.zz7.de
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 28 / 29
