    Modelling a tramway
    595 Posts 43 Posters 449.3k Views 40 Watching
    • jo-keJ
      jo-ke
      http://www.zz7.de
      Reply Quote 3
        Eureka, I think you have it...
        • jo-keJ
          jo-ke
          http://www.zz7.de
          • jo-keJ
            jo-ke
            I started to model that tramway for a 3D Print.
            Meshyscan in foreground
            http://www.zz7.de
            • jo-keJ
              jo-ke
              3D Model is finished:
              this is how the finished model should look like....
              http://www.zz7.de
              Reply Quote 2
                Killer result
                • jo-keJ
                  jo-ke
                  is there a Pugin to draw rails along path?
                  http://www.zz7.de
                    ProfileBuillder would be a good option.
                    Or CurviLoft
                    CurviLoft to make profiles follow a curve in SketchUp
                    • jo-keJ
                      jo-ke
                      I am using profile builder 1 but there is no option for rails
                      http://www.zz7.de
                        I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
                        Using ProfileBuilder 3 in SketchUp to draw train rails
                        • jo-keJ
                          jo-ke
                          I need a path in the middle and two rails (special profile) left and right, to follow the path.
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            next project
                            photo:
                            SU:
                            Render:
                            http://www.zz7.de
                            Reply Quote 2
                              Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                                Rich O Brien Moderator @jo-ke
                                With Curviloft the profiles can be offset from the path...
                                Profile offset from Path using CurviLoft
                                That does mean you need to do each side as a separate operation.
                                Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                                TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                                • jo-keJ
                                  jo-ke
                                  the newer version of profile builder seems to be a good tool.
                                  Is it possible to insert an own profile?
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      http://www.zz7.de
                                      Reply Quote 3
                                        Wunderbar.
                                          Sorry, I missed your query.
                                          Yes, you can create a library of custom profiles.
                                          • majidM
                                            majid
                                            These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                                            jo-keJ 1 Reply Last reply
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
