    Modelling a tramway
    587 Posts 43 Posters 406.7k Views 42 Watching
      Eureka, I think you have it...
      • jo-keJ
        jo-ke
        http://www.zz7.de
        • jo-keJ
          jo-ke
          I started to model that tramway for a 3D Print.
          Meshyscan in foreground
          http://www.zz7.de
          • jo-keJ
            jo-ke
            3D Model is finished:
            this is how the finished model should look like....
            http://www.zz7.de
            Reply Quote 2
              Killer result
              • jo-keJ
                jo-ke
                is there a Pugin to draw rails along path?
                http://www.zz7.de
                  ProfileBuillder would be a good option.
                  Or CurviLoft
                  CurviLoft to make profiles follow a curve in SketchUp
                  • jo-keJ
                    jo-ke
                    I am using profile builder 1 but there is no option for rails
                    http://www.zz7.de
                      I can't remember v1 but v3 has an Along Path option that has rudinmentary support for branching paths.
                      Using ProfileBuilder 3 in SketchUp to draw train rails
                      • jo-keJ
                        jo-ke
                        I need a path in the middle and two rails (special profile) left and right, to follow the path.
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          next project
                          photo:
                          SU:
                          Render:
                          http://www.zz7.de
                          Reply Quote 2
                            Curviloft does a good job to be fair, not sure why you need anything else. Upright extruder perhaps (Or whatever it is called now).
                              Rich O Brien Moderator @jo-ke
                              With Curviloft the profiles can be offset from the path...
                              Profile offset from Path using CurviLoft
                              That does mean you need to do each side as a separate operation.
                              Or with ProfileBuilder 3 (or above) you could make an Assembly with a mix of Profiles and objects like bolts to do it in one sweep.
                              TIG's Extrusion Tools would do it too similar to CurviLofts approach.
                              • jo-keJ
                                jo-ke
                                the newer version of profile builder seems to be a good tool.
                                Is it possible to insert an own profile?
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    http://www.zz7.de
                                    Reply Quote 3
                                      Wunderbar.
                                        Sorry, I missed your query.
                                        Yes, you can create a library of custom profiles.
                                        • majidM
                                          majid
                                          These are fantastic. I think I've missed something: How do you make your models so realistic in renders?
                                          jo-keJ 1 Reply Last reply
                                          • jo-keJ
                                            jo-ke @majid
                                            @majid It is just AI. Gemini does a great job
                                            http://www.zz7.de
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
