    Little touches in SU2015
    16 Posts 11 Posters 1.9k Views 11 Watching
    • AdamBA
      AdamB
      I'm really liking SU2015 - good job team!
      I've noticed a few little things which I'm pretty sure are new..
      • The material browser now retains the aspect ratio of textures in thumbnails so you can see when they're not square.
      • The rect tool when inscribing on a surface can inference an edge and keep the dimension locked and you move perpendicular
      Any other things people have noticed?
      Adam
      • BoxB
        The auto fillet tool.
        and the Crtl modifier on the polygon.
        • Mistro11M
          Mistro11
          Where is the auto fillet tool located? That looks like the arch tool you're using. Are you holding a key to get the fillet function?
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
          • S ShepherdS
            S Shepherd
            It is the arc tool, with a double click.
            S
            • S
              sketchuh
              thanks. also
              "and the Crtl modifier on the polygon." ---> the Ctrl is alt/option on the mac.
              • BoxB
                I'm pretty sure this is new.
                The ability to export .PNGs with transparent background. Making it easy to place your sketches into other images without having to painstakingly remove the background.
                Not to mention silly animations.
                http://i155.photobucket.com/albums/s296/storeben/SU/Globe.gif
                http://i155.photobucket.com/albums/s296/storeben/SU/aa4fc44a-b399-4ae1-8dd0-d3c0d90b09d8.png
                http://i155.photobucket.com/albums/s296/storeben/SU/Toy Car1.gif
                • Mistro11M
                  Mistro11
                  Whoa...I can think of many uses for the PNG export. Especially for post pro work.
                  Another thing with the arch tool- After making an arch in a corner, we can then double-click on the other corners to get matching arches. No more using the measuring tape for this purpose. πŸ˜„
                  Discovered it here http://3dprintboard.com/showthread.php?8223-SketchUp-2015-Update%26amp;p=34424
                  • hellnbakH
                    hellnbak
                    I've been following this thread and have seen some potentially really useful features of 2015 that I might not have (probably wouldn't have) found on my own.
                    If I could ask one thing. Could you specify whether a tip is for the Make version or just the Pro version? Don't want to get all excited about something just to find out it would be kinda expensive for me to be able to use it πŸ˜†
                    • BoxB
                      Mistro, That is what I was showing above, the only difference is when there are two edges it will remove the corner while on 3 edges it only draws the arc.
                      You can see the difference here.
                      http://i155.photobucket.com/albums/s296/storeben/SU/Three Edges.gif
                      As to needing to use the Tape to make your corners even, that's all part of the Inference system and has been around for a long time. By using the inference colours you know when your arc is positioned correctly to get an even fillet. If you need perfectly sized even fillets you only need to measure one point, the starting point of the first arc.
                      A lot of people seem unaware of how useful Magenta is.
                      This is inferencing two even fillets in SU8
                      http://i155.photobucket.com/albums/s296/storeben/SU/Arc Inf.gif
                      And the new look of inference and double click in SU2015
                      http://i155.photobucket.com/albums/s296/storeben/SU/Arc Tangent.gif
                      • Mistro11M
                        Mistro11
                        Box-I wasn't paying attention to the arch size in your first post so didn't pick up on that. Now I feel like a noob again. I was aware of the magenta before but never gave it the respect it deserved. So this is a "Duh" moment for me as I think of how much time I could've saved instead of using the measuring tape in past projects. Guess I need more speed modeling practice. πŸ’š
                        • emerald15E
                          emerald15
                          I hadn't found these new features yet - 'thought it was just rotated rectangles. A great new box of tricks - I know I'll be using all of them.
                          • BoxB
                            The double click on the arc tool is also handy for making curved paths.
                            http://i155.photobucket.com/albums/s296/storeben/SU/Path Arc.gif
                            • 3dita3
                              3dita
                              This feature here is AWESOME!!
                              3dita - Digital Visual Motion
                              • TommyKT
                                TommyK
                                • All of my keyboard shortcuts have been preserved from SU2014! It has been a particularly painless upgrade process this time round.
                                • TIGT
                                    BUT be warned that if you had a shortcut to a menu item under 'Plugins' it won't work.
                                    This is because v2015 renamed that menu item 'Extensions'.
                                    If you only have a few you could reset that manually.
                                    There is a simple fix if you have lots, is to Export the v2015 Prferences from Preferences > Shortcuts.
                                    Then edit that .dat file using Notepad[++] and find/replace 'Plugins/' with 'Extensions/'.
                                    Save the .dat file and Import it under Preferences > Shortcuts.
                                    When prompted accept the overwriting of the unusable 'Plugins/' shortcuts with the 'Extensions/' version.
                                    Even if you do not have a particular Plugin installed that would appear under the 'Extensions' rather than the old 'Plugins' menu, that shortcut remains valid and will work should you choose to install the matching Plugin it refers to...
                                  • V
                                    valerostudio
                                    I took SU2015 as an opportunity to house clean as I have always ctrl+c copied plugins from one version to the next and the same with my shortcuts. I manually reinstalled all of my favorite plugins and tossed the old ones that never really used. Then I ran this script in the ruby console and went through all of my shortcuts. Some I knew, some I had no idea.
                                    UI.messagebox(Sketchup.get_shortcuts.join("\n"), MB_MULTILINE)
