    Vray 2014 work in sketchup pro 2015?
    renderpluginsextensions
    21 Posts 15 Posters 29.7k Views 15 Watching
    • kaluK
      kalu
      Hi Guys:
      I upgrade my license of Sketchup pro 2015 but I do not install since I WORK 100% on Vray I need to know If someone try and work with the vray version 2014 in OS X?
      Thanks in advance for the info.
      Gonzalo. 😎
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • andybotA
        andybot
        best to wait until ChaosGroup has a release for SU2015. I would stick with previous versions until then.
        • KrisidiousK
          Krisidious
          You can install SU2015 without affecting SU2014. why not try and install it and see if it works?
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59648%26amp;p=543184#p543184
            By: Kristoff Rand
            • D
              Dentice
              Ive email Chaos Group and theyve told me that they`re working on an upgrade for SketchUp 2015. They should be releasing an upgrade anytime soon!
              • M
                mikahberci
                I have SketchUp Pro 15 with license and everything on my laptop and I just tried to install a demo version of Vray 2.0 and it won't work. I use Windows, but I guess is the same thing for Mac.
                Hope this helps
                • cmdC
                  cmd
                  The Vray update for SketchUp 2015 is now available
                  http://www.chaosgroup.com/en/2/news.html?i=615#newsid615
                  Cheers
                  CMD
                  • CMD
                  • chonC
                    chon
                    Good news ! πŸ‘
                    Does this release solve this known bug ?
                    SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                    • dkendigD
                      dkendig
                      that bug should have been addressed, yes
                      Devin Kendig
                      Developer
                      • V
                        vladumi
                        How to install Vray 3.0 pack to Sketchup 2015 instead of the version 2014? I installed the new version but even after I selected the 2015 directory is still installed for 2014 not showing in 2015. I don't want to remove yet 2014 but wanted to test vray in 2015. Hope I can get some help,
                        • andybotA
                          andybot
                          unfortunately, you can only have one version installed. I'd recommend using the SU2015 x64 version.
                          • V
                            vladumi
                            I don't know how to switch vray currently installed for SU 2014 to my newer 2015 version. I tried to update using 2015 directory but is still working on the 2014 version. I need to switch them
                            • andybotA
                              andybot
                              you can't just switch. You need to uninstall the old version, then install the new version.
                              • E
                                elisman
                                • V
                                  valerostudio
                                  Download the latest installer from Chaos for 2015 x64 and it will take you through the process.
                                  • dkendigD
                                    dkendig
                                    it might be possible to have the 32bit version of 2015 installed, and have it work in both 2014 and 2015, but if you install 2015 64bit (which I entirely recommend), you can't have V-Ray in both 2014 and 2015. (why are you using 2014 32bit at all if you have 2015 64bit??)
                                    Devin Kendig
                                    Developer
                                    • C
                                      carconcal
                                      Why i can only download the vray demo version for 64x? it has lot of limits... i purchase the version 2.0 but i can't download the complete version for vray 64 by the way i love sketchup 64x i have no crashes!
                                      • dkendigD
                                        dkendig
                                        looks like there's an issue with your account permissions. Contact support@chaosgroup.com so we can fix that for you carconcal.
                                        Devin Kendig
                                        Developer
                                        • C
                                          cmassner
                                          I have Vray for SketchUp 2014 and getting ready to purchase SketchUp 2015. Will I be able to use my existing Vray license and dongle and just download the new version of Vray, or will I need to purchase the newest version?
                                          • C
                                            cadmunkey
                                            Is Vray4SU GPU based or CPU based?
                                            • 1 / 2
