    Vray 2014 work in sketchup pro 2015?
    renderpluginsextensions
    21 Posts 15 Posters 29.3k Views 15 Watching
      mikahberci
      I have SketchUp Pro 15 with license and everything on my laptop and I just tried to install a demo version of Vray 2.0 and it won't work. I use Windows, but I guess is the same thing for Mac.
      Hope this helps
      • cmdC Offline
        cmd
        The Vray update for SketchUp 2015 is now available
        http://www.chaosgroup.com/en/2/news.html?i=615#newsid615
        Cheers
        CMD
        • CMD
        • chonC Offline
          chon
          Good news ! πŸ‘
          Does this release solve this known bug ?
          • dkendigD Offline
            dkendig
            that bug should have been addressed, yes
            Devin Kendig
            Developer
            • V Offline
              vladumi
              How to install Vray 3.0 pack to Sketchup 2015 instead of the version 2014? I installed the new version but even after I selected the 2015 directory is still installed for 2014 not showing in 2015. I don't want to remove yet 2014 but wanted to test vray in 2015. Hope I can get some help,
              • andybotA Offline
                andybot
                unfortunately, you can only have one version installed. I'd recommend using the SU2015 x64 version.
                • V Offline
                  vladumi
                  I don't know how to switch vray currently installed for SU 2014 to my newer 2015 version. I tried to update using 2015 directory but is still working on the 2014 version. I need to switch them
                  • andybotA Offline
                    andybot
                    you can't just switch. You need to uninstall the old version, then install the new version.
                    • E Offline
                      elisman
                      @andybot said:
                      best to wait until ChaosGroup has a release for SU2015. I would stick with previous versions until then.
                      • V Offline
                        valerostudio
                        Download the latest installer from Chaos for 2015 x64 and it will take you through the process.
                        • dkendigD Offline
                          dkendig
                          it might be possible to have the 32bit version of 2015 installed, and have it work in both 2014 and 2015, but if you install 2015 64bit (which I entirely recommend), you can't have V-Ray in both 2014 and 2015. (why are you using 2014 32bit at all if you have 2015 64bit??)
                          Devin Kendig
                          Developer
                            carconcal
                            Why i can only download the vray demo version for 64x? it has lot of limits... i purchase the version 2.0 but i can't download the complete version for vray 64 by the way i love sketchup 64x i have no crashes!
                            • dkendigD Offline
                              dkendig
                              looks like there's an issue with your account permissions. Contact support@chaosgroup.com so we can fix that for you carconcal.
                              Devin Kendig
                              Developer
                                cmassner
                                I have Vray for SketchUp 2014 and getting ready to purchase SketchUp 2015. Will I be able to use my existing Vray license and dongle and just download the new version of Vray, or will I need to purchase the newest version?
                                  cadmunkey
                                  Is Vray4SU GPU based or CPU based?
                                    rspierenburg
                                    CPU based but there is provision to use GPU for RealTime (RT) rendering.
