    Vray 2014 work in sketchup pro 2015?
    renderpluginsextensions
    21 Posts 15 Posters 29.3k Views 15 Watching
    • KrisidiousK Offline
      Krisidious
      You can install SU2015 without affecting SU2014. why not try and install it and see if it works?
      By: Kristoff Rand
        Krisidious
        http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59648%26amp;p=543184#p543184
        By: Kristoff Rand
          Dentice
          Ive email Chaos Group and theyve told me that they`re working on an upgrade for SketchUp 2015. They should be releasing an upgrade anytime soon!
            mikahberci
            I have SketchUp Pro 15 with license and everything on my laptop and I just tried to install a demo version of Vray 2.0 and it won't work. I use Windows, but I guess is the same thing for Mac.
            Hope this helps
            • cmdC Offline
              cmd
              The Vray update for SketchUp 2015 is now available
              http://www.chaosgroup.com/en/2/news.html?i=615#newsid615
              Cheers
              CMD
              • CMD
              • chonC Offline
                chon
                Good news ! πŸ‘
                Does this release solve this known bug ?
                • dkendigD Offline
                  dkendig
                  that bug should have been addressed, yes
                  Devin Kendig
                  Developer
                  • V Offline
                    vladumi
                    How to install Vray 3.0 pack to Sketchup 2015 instead of the version 2014? I installed the new version but even after I selected the 2015 directory is still installed for 2014 not showing in 2015. I don't want to remove yet 2014 but wanted to test vray in 2015. Hope I can get some help,
                    • andybotA Offline
                      andybot
                      unfortunately, you can only have one version installed. I'd recommend using the SU2015 x64 version.
                      • V Offline
                        vladumi
                        I don't know how to switch vray currently installed for SU 2014 to my newer 2015 version. I tried to update using 2015 directory but is still working on the 2014 version. I need to switch them
                        • andybotA Offline
                          andybot
                          you can't just switch. You need to uninstall the old version, then install the new version.
                          • E Offline
                            elisman
                            @andybot said:
                            best to wait until ChaosGroup has a release for SU2015. I would stick with previous versions until then.
                            • V Offline
                              valerostudio
                              Download the latest installer from Chaos for 2015 x64 and it will take you through the process.
                              • dkendigD Offline
                                dkendig
                                it might be possible to have the 32bit version of 2015 installed, and have it work in both 2014 and 2015, but if you install 2015 64bit (which I entirely recommend), you can't have V-Ray in both 2014 and 2015. (why are you using 2014 32bit at all if you have 2015 64bit??)
                                Devin Kendig
                                Developer
                                  carconcal
                                  Why i can only download the vray demo version for 64x? it has lot of limits... i purchase the version 2.0 but i can't download the complete version for vray 64 by the way i love sketchup 64x i have no crashes!
                                  • dkendigD Offline
                                    dkendig
                                    looks like there's an issue with your account permissions. Contact support@chaosgroup.com so we can fix that for you carconcal.
                                    Devin Kendig
                                    Developer
                                      cmassner
                                      I have Vray for SketchUp 2014 and getting ready to purchase SketchUp 2015. Will I be able to use my existing Vray license and dongle and just download the new version of Vray, or will I need to purchase the newest version?
                                        cadmunkey
                                        Is Vray4SU GPU based or CPU based?
                                          rspierenburg
                                          CPU based but there is provision to use GPU for RealTime (RT) rendering.
