    Vray 2014 work in sketchup pro 2015?
    renderpluginsextensions
    21 Posts 15 Posters 29.3k Views 15 Watching
    • dkendigD Offline
      dkendig
      that bug should have been addressed, yes
      Devin Kendig
      Developer
      • V Offline
        vladumi
        How to install Vray 3.0 pack to Sketchup 2015 instead of the version 2014? I installed the new version but even after I selected the 2015 directory is still installed for 2014 not showing in 2015. I don't want to remove yet 2014 but wanted to test vray in 2015. Hope I can get some help,
        • andybotA Offline
          andybot
          unfortunately, you can only have one version installed. I'd recommend using the SU2015 x64 version.
          • V Offline
            vladumi
            I don't know how to switch vray currently installed for SU 2014 to my newer 2015 version. I tried to update using 2015 directory but is still working on the 2014 version. I need to switch them
            • andybotA Offline
              andybot
              you can't just switch. You need to uninstall the old version, then install the new version.
              • E Offline
                elisman
                @andybot said:
                best to wait until ChaosGroup has a release for SU2015. I would stick with previous versions until then.
                • V Offline
                  valerostudio
                  Download the latest installer from Chaos for 2015 x64 and it will take you through the process.
                  • dkendigD Offline
                    dkendig
                    it might be possible to have the 32bit version of 2015 installed, and have it work in both 2014 and 2015, but if you install 2015 64bit (which I entirely recommend), you can't have V-Ray in both 2014 and 2015. (why are you using 2014 32bit at all if you have 2015 64bit??)
                    Devin Kendig
                    Developer
                      carconcal
                      Why i can only download the vray demo version for 64x? it has lot of limits... i purchase the version 2.0 but i can't download the complete version for vray 64 by the way i love sketchup 64x i have no crashes!
                      • dkendigD Offline
                        dkendig
                        looks like there's an issue with your account permissions. Contact support@chaosgroup.com so we can fix that for you carconcal.
                        Devin Kendig
                        Developer
                          cmassner
                          I have Vray for SketchUp 2014 and getting ready to purchase SketchUp 2015. Will I be able to use my existing Vray license and dongle and just download the new version of Vray, or will I need to purchase the newest version?
                            cadmunkey
                            Is Vray4SU GPU based or CPU based?
                              rspierenburg
                              CPU based but there is provision to use GPU for RealTime (RT) rendering.
