    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 130.6k Views 39 Watching
    • fredo6F Offline
      fredo6
      Because of the two holes, the front face will become quite busy with edges when you carve the logo. If your model is at small scale, this can generate issues with the shape being manifold.
      Possibly, you may try by putting rectangular edges around the holes over the main face to isolate them.
        Buckyman
        Or do the carve first, Holes after??
        • H Offline
          Hannahdesigns88
          When I try to download this visuhole plug in, it says its not a sketchup model and wont let me download it...or even begin to download. I have sketch up pro 2022 windows.
            Extensions cannot be opened by SketchUp. You need to use Extensions > Extension Manager to install the .RBZ file
            • BoxB Offline
              To follow on from Rich's comment, it sounds like you have the download dialog set to 'Open with' rather than 'Save File' You need to set it to save file to get the RBZ to your computer to then get the extension manager to use it.
              • P Offline
                ploniman
                it doesnt work as it should. tried several fonts but, always with little errors. see picure
                what to do?
                • BoxB Offline
                  Scale is the first most likely issue, how small is your model.
                  Scale up by 100 and see if it works.
                    what to do?
                    [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
                    Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
                    • ezyuzinE Offline
                      ezyuzin Extension Creator
                      Hello,
                      Is it possible to create holes with specific depth in multilayer objects
                      For sample, I was unable to find correct results
                      using drill and carve commands
                        To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
                        But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
                        • ezyuzinE Offline
                          It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
                          I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
                            mac13517a
                            Great Plugin, I love it a LOT!!!
                            I have a question: How can I remove a stencil???
                            Sometime I just require upgrade the stencil or simply remove the old stencil.
                            Kind regards,
                            • F Offline
                              faustcan
                              Hello, where is the download link to Visuhole, please? I bought the licence for 8 plugins including this. Many thanks
                                Open ExtensionStore dialog in SketchUp
                                Click the Paste URL icon
                                https://i.imgur.com/glZOdES.png
                                In the input put pln=visuhole and click Install
                                https://i.imgur.com/URWwE2D.png
                                Restart SketchUp
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: VisuHole v1.5a - 01 Apr 24
                                  Requirements:
                                  • LibFredo6 v14.3b
                                  • Sketchucation Plugintore v4.4.0
                                  VisuHole 1.5a is a maintenance release for
                                  • Future compatibility
                                  Home Page of VisuHole for information and Download.
                                  Main post of this VisuHole thread.
                                  • I Offline
                                    ivansmirnov333 Newcomers
                                    Visuhole.
                                    Hello! I'm trying to make a hole in the selection component. What do I do wrong?
                                    Screen Video: link
                                    TIGT 1 Reply Last reply Reply Quote 1
                                      TIG Moderator @ivansmirnov333
                                      @ivansmirnov333
                                      You give too much AND not enough information…
                                      Can you explain what the carious bits are, and what you are trying to do, and preferably attached a simple SKP showing the problem, with steps if necessary - currently your movie is unclear…
                                      I 1 Reply Last reply Reply Quote 0
                                      • I Offline
                                        ivansmirnov333 Newcomers @TIG
                                        @TIG Sorry. New video with my explanations is here: link
                                        SKP is attached.
                                          @ivansmirnov333
                                          This really needs @fredo6 's expertise, but as far as I can see the vertical component with the holes is nested inside a component of several pieces.
                                          If you do not edit and select the appropriate context then the hole cutting doesn't occur in the component ?
                                          • I Offline
                                            @TIG no, nothing changes too
                                            I 1 Reply Last reply Reply Quote 1
                                            • 6
                                            • 5 / 6
