    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.5k Views 155 Watching
      3dsmax9
      this tool is amazing i just wish if it is possibele to add the undo and redo botton like in the oldest version it wash mutch quicker tu redo the last action that way, and thanks for all your amazing plug in
      • fredo6F
        fredo6
        To Undo, you can freely use Ctrl-Z within the plugin, or click on the Orange backtrack Arrow in the button palette.
        To redo, select the faces you want to push-pull and just double click
        Fredo
        • panixiaP
          panixia
          @tig said:
          Incidentally, what exactly are these listed items ?
          Dialog Bulge Push Smooth Smudge Grab Planar Lock
          404 Not Found
          (sketchucation.com)
          • D
            David.P
            As a brand new user to Fredo's tools I am sure that this is all incredibly amazing.
            Only thing is that the GUI looks garbled on pretty much anything other than the standard DPI settings of Windows (which is much too low for nowadays high resolution screens):
            http://666kb.com/i/cm74vc86gocwgwb5h.png
            This is with Windows screen DPI set to 125%.
            Anyway, keep up the great work
            Regards David.P
              Except the basic but robust graphic aspect does the functions are good working ? πŸ˜‰
              • D
                David.P
                Honestly, the obvious abundance of functions has frightend me off so far -- all the more since (additionally) I can't really seem to read what everything does. It's stupid I know, but maybe it is only decades of bad experience with garbled UI's that puts me off to even try and touch these tools.
                  Sure, it's a program inside program but..take your time to experiment! πŸ˜‰
                  Maybe there is inside the function that you have always dreamed! β˜€
                  • U
                    unearthed
                    Agree with Pilou 100% - the plugin writers on here are coming from dozens of different design backgrounds and cultures - so you can expect some individuality in interfaces (and some unique and different approaches to problems), and fredo's tools are great tools - out of all the tools I suggest you start on something like vector or normal (multi-face push-pull) they're pretty amazing all on their own, some serious time savers here.
                    Growplan - People ∩ Plants ∩ Place
                    windows 7 64b, 4GB RAM, SU 8.0.16846
                    Gimp, QGIS, Vectorworks 12, Bricscad 11
                    • fredo6F
                      fredo6
                      Regards David.P
                      It is advised to keep a 100% resolution because the scripts have no control over the size of the text displayed in the GUI.
                      Some functions are also available in the VCB and contextual menus.
                      Fredo
                      • F
                        fantoosh420
                        Fredo
                        It is for you. please investigate the file.. Joint Push pull not working. giving error.
                        TO SKETCHUCATION.skp
                        Sketchup 14.0.4900
                        Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
                        • fredo6F
                          fredo6
                          Thanks for signaling.
                          It is on my list to provide a safe generation mode, as a backup to the current generation mode (which is fast, but assumes the shape is not ill-formed).
                          For your model, the problem comes from a lot of lonely vertices (i.e. split edges).
                          I suggest you clean them up with, for instance, FredoTools::EdgeInspector or Thomthom's Cleanup.
                          Then the generation happens without error.
                          Fredo
                          • TIGT
                            @Amit
                            Use Fredo's Tools to 'Remove Lonely Vertices' - you have several unneeded vertices along the edges of the form.
                            These are very closely spaced and create overlapping extrusions making it fail
                            Retry JointPushPull on the corrected form - it will then work...
                            I just tried it and it worked...
                            [Fredo beat me to it ! πŸ˜’ ]
                            • F
                              fantoosh420
                              @ Fredo & TIG
                              I already cleaned that before you guys mentioned it but i thought i would be good to share it with you guys so that if it is happening because of any undiscovered reason it can be sorted out.
                              As far as having a lot of lonely vertices, it is because of the organic nature of modelling i am currently doing. i am doing a hotel project on the hill and a meandering road was also being modelled which is meant to access the hotel (the surface i sent was one face of a retaining wall coming along the road). I was doing it without cleaning up the geometry due to save time and end the end spent all the saved time due to problem. πŸ˜„ πŸ˜„... never mind since fredo is aware of the situation, a solution is inevitable.
                              Sketchup 14.0.4900
                              • F
                                fantoosh420
                                and bi the way fredo, how can i donate you? i don't have a credit card so facing problem... i wanted to donated to TIG to for cutNfill plugin but same problem happened. is there any other way? if no easy way out then i guess i need to figure out a credit card from any of my friend.
                                Sketchup 14.0.4900
                                • TIGT
                                  We'll both accept PayPal donations.
                                  You can link those to a Bank-Account without any Credit-Card being needed... πŸ˜•
                                  • F
                                    fantoosh420
                                    @ TIG.. i tried that.... i guess direct debit by paypal from bank account is not supported here in India. My bank account is connected to paypal but even then it asks for a credit card. it says bank account is to credit money into your account but for debit you need a card. may be i need to figure out a credit card only...
                                    Sketchup 14.0.4900
                                    • R
                                      Ruf85
                                      sorry I have this problem with the last version.
                                      Why?
                                      When I use the Round push pull
                                      Date: 07-Mar-14 16:10:03
                                      An error occured in Round Push Pull
                                      Error in generation of the geometry
                                      undefined method `line_vec=' for nil:NilClass
                                      JointPushPullGeometry.rb: 1450 -- geometry_rounding_mesh
                                      JointPushPullGeometry.rb: 1275 -- geometry_create_roundings
                                      JointPushPullGeometry.rb: 1274 -- each
                                      JointPushPullGeometry.rb: 1274 -- geometry_create_roundings
                                      JointPushPullGeometry.rb: 262 -- geometry_robot_prepare_mesh
                                      JointPushPullGeometry.rb: 206 -- robot_call_action
                                      JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                                      JointPushPullGeometry.rb: 160 -- geometry_robot
                                      JointPushPullGeometry.rb: 75 -- geometry_execute
                                      Lib6Operation.rb: 317 -- call
                                      Lib6Operation.rb: 317 -- step_geometry
                                      Lib6Operation.rb: 358 -- start_execution
                                      JointPushPullTool.rb: 879 -- go_preview_or_geom
                                      JointPushPullTool.rb: 690 -- dragging_stop
                                      JointPushPullTool.rb: 1303 -- onLButtonUp
                                      • fredo6F
                                        fredo6
                                        @ruf65,
                                        Could you post or PM me the model. I found the problem but would like to check that this is cured.
                                        Fredo
                                        • R
                                          Ruf85
                                          Sorry for the delay.
                                          It's an element of the roof tile. I would model the front side.
                                          Just for teach I use your plugins but I had the error
                                          sorry for my bad english. I hope you understand me.
                                          SKUpro8
                                          • brodieB
                                            brodie
                                            I'm used to the old JPP so I'm not used to all of the options with the new one which may be causing my issue here. When I use JPP on a cone instead of basically making a bigger cone it pushes the point off to one side and does some weird stuff at the base.
                                            What am I doing wrong here?
                                            -Brodie
                                            • 6
                                            • 30
                                            • 31
                                            • 4 / 31
