    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 789.2k Views 155 Watching
      Certainly special characters like é or ö will break the current version of Ruby that ships with SketchUp.
      The ' is a special case, because it breaks some Ruby and js when passed in a string that is 'raw'.
      The author can use " " to encapsulate Ruby string parts so the included ' is preserved.
      Or if the encapsulation is ' ' it must then be escaped - tr("'","'") for js use it's best perhaps as say tr("'","\\'") ...
      But for now please leave ' out of your path-names - there are many alternatives... 😒
      • N Offline
        numerobis
        Almost two months online already... How could i miss this one?!? 😮
        Unbelievable! You've done it again... Great improvement! 😎
        I'm not sure if the sketchup "developers" are still following what's going on with their software on plugin level... If i would be in their position i would really be ashamed...
        • E Offline
          Elmer BeFuddled
          @cotty said:
          You should never use special characters in path names!
          in your case: '13...
          Right, I shall remove the offending "happy oz trophy" (which is a straight one, nothing oblique or fancy) from the SU file path.
          Its never affected any thing else when I abb. (tee hee!! 😉 ) the date in the path name but I'll be honest, up until ten days ago I'd never heard of Ruby, heathen that I am!!
          A thought. A.N.Other plug-in, the SVG importer that required rexml (from Ruby) to be added into the plug-ins folder didn't work either, though I can't remember the error msg. I received.
          It may also be why I can't import *.dxf files from Inkscape that were made from a *.pdf files that were made in Photoshop from *.psd files that were made from thoughts in my single malt, whisky hazed mind!
          Back to the point, I'll update you with as to how things went.
          !!! HOT OFF THE PRESSES !!!
          An Update.
          Well, I re-installed SU to C:\Program Files (x86)\DEVELOP\SketchUp 13 and Ruby to C:\Program Files (x86)\DEVELOP\Ruby193 and voila!! Joint Push Pull and Tools on Surface both popped up their toolbars when I opened up SU.
          Who'd have thunked a little apostrophe could cause so much hassle!
          That would never of crossed my mind as I've been 'apostrophising' install paths and file names since Jesus left Kilmarnock (a.k.a a very long time) with no issues. Strange how the parenthesis as in (x86) get ignored!
          Still having problems with the svg importer (the error message shows one oblique and one straight comma) but I'll post about that in the correct place.
          Many many thanks to you cotty and TIG for your help. I'd have got nowhere without it.
          Elmer
          • fredo6F Offline
            fredo6
            NEW RELEASE: JointPush Pull Interactive v3.2a - 25 Jan 14
            JointPushPull Interactive 3.2a includes a Projected mode for Vector Push-Pull (see video).
            [flash=425,344:3hd996ii]http://www.youtube.com/v/qsKZpmrJkxs&hl[/flash:3hd996ii]
            See main post of this thread for Download.
            Fredo
            • cottyC Offline
              cotty
              One WOW! per day, a good average 😉
              my SketchUp gallery
              • CadFatherC Offline
                CadFather
                wow indeed, here's a scary thought... ..imagine life without Fredo6..... 😲 😆
                  babak
                  Happy new year and thank you very much !
                    Hello Fredo
                    Does it possible to keep a multiple selection result of a JPP for another "Joint Push Pull" ?
                    CTRL seems don't working! 😕
                    If not does exist a plugin for a "circular selection" ?
                    Will be cool in this case (for select all vertical faces) and many other cases! 😄
                    A general circular selection will be sufficient with the help of the Inverse Selection existing! 😉
                    On the right one result wanted...sor many other JPP are missing! 😄
                    • N Offline
                      numerobis
                      did you try to recall the last selection?
                      http://sketchucation.com/pluginstore?pln=tt_selection_memory
                        No! I will try that! 😄
                        But Circular selection wiil be also a cool thing for another thing if possible! 😄
                          @numerobis
                          I have used the Thomthom Recall last selection but alas that can't work in this case because of course it's a new selection never yet selected! 😮
                            Ben Ritter
                            Fredo, thank you!!!!
                              Seems you can make something with the Taper function inside the plugin?
                              But seems you don't escape to make an intersection and some delete! 😲
                              would love if anyone could give an alternate solution 😃
                              if you have the Pro seems boolean solids Difference will be fine ?
                                And it's maybe more tricky to make a thickness with The JPP ! 😉
                                You will obtain more easily that you want! 😄
                                  Another thing to consider is that changing the order in which you do things might change the outcome. Pilou's second example shows that with his opening drawn before the wall is given thickness. An alternative might be as shown below.
                                  Or maybe you break the thing down into a single copy of the repeating element and, once you've drawn it, copy that as needed.
                                    TechnoGuru
                                    Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
                                    Thanks CC
                                      Thanks CC
                                      You could try this thread: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17947 but you should really install the Sketchucation Plugin Store and auto-install plugins.
                                        BruceG
                                        I've installed the latest version and still have no luck with the new joint push pull in Windows 8.1. The old joint push pull still functions. I have a similar problem with AMD 7700 video card with latest updated driver and the following installed
                                        extensions:SketchUcation
                                        3DxSketchUp
                                        BezierSpline
                                        Dialog
                                        Bulge
                                        Push
                                        Smooth
                                        Smudge
                                        Grab
                                        Planar Lock
                                        Arcs Circles
                                        Fredo6 LibFredo6
                                        Fredo6 Curviloft
                                        Fredo6 Curvizard
                                        Fredo6 FredoScale
                                        Fredo6 Fredo Tools
                                        Fredo6 JointPushPull
                                        Fredo6 Round Corner
                                        Fredo6 Tools on Surface
                                        JointPushPull
                                        quarr_jsalign
                                        s4u-AlignTool
                                        STL Import & Export
                                        CleanUp³
                                        TT_Lib²
                                        Edge Tools²
                                        Solid Inspector
                                        Any suggestions?
                                          You have the new AND old versions of JointPushPull listed.
                                          Disable the older one and restart and see if that helps.
                                          If so, then remove its .rb file permanently from the Plugins folder: it is not normally meant to load side by side with the newer 'Fredo...' version. 😕
                                          Incidentally, what exactly are these listed items ?
                                          Dialog Bulge Push Smooth Smudge Grab Planar Lock
                                          I assume you do mean Extensions rather than Plugins ?
                                          What does their description say ??
                                          Also giving us info in your SCF User Profile - about your OS and SketchUp version helps us help you 😒
                                          • fredo6F Offline
                                            fredo6
                                            For info, the old and new versions of Joint Push Pull can safely coexist.
                                            And all my plugin are enabled as active extension by default and have their Toolbar visible by default at first installation.
                                            I think the problem comes from a wrong installation, and anyway should be clarified by BruceG. What is the problem exactly?
                                            • the plugin does not appear
                                            • There is an error message at startup of Sketchup
                                            • JPP 3.2 does crash or does nothing when launched,
                                            • etc...
                                            Without this information, it is difficult to assist.
                                            Fredo
                                            • 30
                                            • 31
                                            • 3 / 31
