    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.5k Views 155 Watching
    • H
      hebeijianke
      There are two strings cannt be translated
      Processing time = %1s
      Time calculation =
      • fredo6F
        fredo6
        Time calculation =
        There may be a problem with the = sign.
        So just use : instead for the time being
        Fredo
          Effectively Tapering negative gives some funny results! 😄
          • bagateloB
            bagatelo
            Very good job! Thanks!
            And about to make the object like before the operation by this plug in? Will be great...
            • fredo6F
              fredo6
              NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
              JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
              See main post of this thread for Download.
              Fredo
              • OxerO
                Oxer
                Thanks you very much!! 😍
                I needed some of new features. I have created the new spanish (Spain) language file
                Spanish (Spain) Language File
                http://www.oxervision.blogspot.com/
                • mitcorbM
                  mitcorb
                  Salutations Fredo:
                  I like your new version. However, I will not download until I can make a donation.
                  • LAGRARI2012L
                    LAGRARI2012
                    Thanks you very much 👍
                    • B
                      BruceG
                      Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                      • chonC
                        chon
                        Hello,
                        i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... 😉
                        Fredo ? Any help ? 💚
                        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                        • fredo6F
                          fredo6
                          NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
                          JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
                          Fredo
                          • blackquodB
                            blackquod
                            Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                            • K
                              kaas
                              any chance you know whats causing this error?
                              Date: 11-Dec-13 15:01:48
                              An error occured in Joint Push Pull
                              Error in Analysis of model
                              undefined method `entityID' for nil:NilClass
                              JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
                              JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
                              JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
                              JointPushPullTool.rb: 892 -- modify_preparation
                              JointPushPullTool.rb: 910 -- modify_execute
                              JointPushPullTool.rb: 931 -- modify_offset
                              JointPushPullTool.rb: 1128 -- execute_validate
                              JointPushPullTool.rb: 1327 -- onReturn
                              • fredo6F
                                fredo6
                                It's a small bug when
                                • you do a first Push pull
                                • then you press Return, whereas there is no face selected
                                I'll fix it in a next release
                                Fredo
                                  does this is possible or I miss something ?
                                  (i have not tested with the new version)
                                  JPPv6.skp
                                    It worked for me, Pilou. You should try it.
                                      With the old version the best was that! 😲
                                      Cool now with this new version that is working as wished! 👍
                                      • R
                                        rekin0
                                        Thanks a lot!
                                        • E
                                          Elmer BeFuddled
                                          Greetings!
                                          I'm having a problem with trying to use this tool. When I open SU I get an error msg regarding LibFredo as below:
                                          Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6/__loader.rb
                                          (eval);1;in `effective_load_part2'; compile error
                                          (eval);1; syntax error, unexpected tINTEGER, expecting ')'
                                          ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6', '...
                                          (eval);1; syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                                          ... '13/Plugins/Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM =...
                                          (eval);1; syntax error, unexpected tCONSTANT, expecting kEND
                                          ...Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.cre...
                                          ..._PLATFORM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;...
                                          ...RM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;end
                                          (eval);1; unterminated string meets end of file
                                          (eval);1; syntax error, unexpected $end, expecting kEND
                                          ... 'PC' ;RUN_ON_MAC = false ;end
                                          Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface/__loader.rb
                                          ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface...
                                          (eval);1; syntax error, unexpected tSTRING_BEG, expecting kDO or '{' or '('
                                          ...Plugins/Fredo6_ToolsOnSurface', 'ToolsOnSurface') ; MYDEFPAR...
                                          ...olsOnSurface', 'ToolsOnSurface') ; MYDEFPARAM = MYPLUGIN.cre...
                                          I've just installed Ruby, as well, although not where it wants to go (in the root of C:. Nothing goes there unless Security logs!) Its been installed to the same sub-folder in Program Files as SketchUp.
                                          Any hints or tips to help me?
                                          On a good note (always leave 'em happy Elmer!!) I've just installed the bezier curve tool. What a little beauty!!
                                          • cottyC
                                            cotty
                                            You should never use special characters in path names!
                                            in your case: '13...
                                            my SketchUp gallery
                                            • 30
                                            • 31
                                            • 2 / 31
