    Geometry weirdness
    19 Posts 6 Posters 1.3k Views 6 Watching
    • StinkieS Offline
      Stinkie
      Anyone know how to remedy this? I'm using Vray, btw, but the problem's also there when using Thea.
      • StinkieS Offline
        Stinkie
        Come on, people, chop-chop! I need answers here! πŸ‘Ώ
        Seriously, though, if someone knows how to remedy this, I'd be over the moon. I will handsomely reward him or her. Gold! Diamonds! Land! Livestock! Copious amounts of highly experimental drugs!
        Bit wound up. Don't know if you can tell? 😎
        • jeff hammondJ Offline
          jeff hammond
          it's too hard to know what the problem is.. you know what you're looking at here and what problem you're having..
          we don't πŸ˜‰
          rephrase the question?
          dotdotdot
          • FrederikF Offline
            Frederik
            I agree...
            I saw the post yesterday, but didn't know exactly what to look for... 😳
            Left it to let others chime in... πŸ˜„
            What about a part of the model, where this issue is present...?
            Cheers
            Kim Frederik
            • cottyC Offline
              cotty
              Perhaps some very acute angles?
              my SketchUp gallery
              • StinkieS Offline
                Stinkie
                Cotty, Jeffy, Kimmy,
                What you're looking at, is a pyramid shape. I've bevelled the edges that meet in the pyramid's point, using RoundCorner. The black 'lines' you see in the render (marked 'this sht' in the pic below), should not be there. Looks like polys going 'right, friday night, let's get hammered and fck sh*t up'.
                Yours,
                Tommy
                  have you double verts?
                  • StinkieS Offline
                    Stinkie
                    No idea, Rich. How do I check? (I did run TT's CleanUp tools -render looked similar.)
                    I'll upload the pyramid thingy tommorow morning. Thanks for any help. Let me know what kind of drugs you prefer.
                      Run Fredo's Remove Lonely Vertex tool. It'll mark and remove any shitty stuff.
                      But share it when you get time.
                      • StinkieS Offline
                        Stinkie
                        Oh, excellent! I'll try that.
                        But share it when you get time.[/quote]
                        I will.
                        Nighty-night, gents.
                          jeff hammond
                          (marked 'this sh*t' in the pic below)
                          πŸ˜†
                          oh.. that.. thanks for clearing it up.
                          but i don't know.. rich's suggestion sounds like a good start..
                          if not, maybe post a hidden line view.
                          dotdotdot
                          • cottyC Offline
                            cotty
                            For me, it looks like a displacement problem because of very long but narrow tiangles. Do you have a view of the hidden lines?
                            my SketchUp gallery
                            • StinkieS Offline
                              Stinkie
                              Looks like it, yes, but I'm not using any displacement.
                              Did as Rich suggested. No change.
                              Here's the thingy.
                              wtf.skp
                              • cottyC Offline
                                cotty
                                The faces are triangulated while the export for a renderer and the very long and narrow faces become a problem. In the following example, I used Artisans knife tool to shorten those faces and the problem was solved...
                                (Rendered with Indigo and "random triangle color" option)
                                my SketchUp gallery
                                • BoxB Offline
                                  I suspect it's caused by round corner struggling to make the tiny faces needed. The pyramid isn't "small" but the four edges coming together at a sharp angle and the smallness of your rounding are forcing it to make some very tiny triangles.
                                  Perhaps if you scale up before using round corner it wont tear.
                                  • StinkieS Offline
                                    Stinkie
                                    Box, thanks for the suggestion. However, I did scale the pyramid up before bevelling.
                                    Cotty, you're a bl**dy genius. I am going to try your suggestion right now!
                                    Edit: works! Cotty -thanks so much. The rest of you: shakes head dissaprovingly
                                    About the diamonds etc, I lied.
                                    • StinkieS Offline
                                      Stinkie
                                      Hmmm ... got the problem in other models as well. SU doesn't like tight bevels, it seems. Maybe it's finally time to get that new Modo license. grumbles
                                        SU doesn't obey normal modeling principles. NGons = bad mesh and uv's.
                                        Triangulation equals messy uv's.
                                        • StinkieS Offline
                                          Stinkie
                                          Yeah ... I knew that. Hadn't realised so far it was this bad, though. Maybe I ought to try TT's Quad Face Tools.
