    Geometry weirdness
    19 Posts 6 Posters 1.4k Views 6 Watching
      have you double verts?
      • StinkieS Offline
        Stinkie
        No idea, Rich. How do I check? (I did run TT's CleanUp tools -render looked similar.)
        I'll upload the pyramid thingy tommorow morning. Thanks for any help. Let me know what kind of drugs you prefer.
          Run Fredo's Remove Lonely Vertex tool. It'll mark and remove any shitty stuff.
          But share it when you get time.
          • StinkieS Offline
            Stinkie
            Oh, excellent! I'll try that.
            But share it when you get time.[/quote]
            I will.
            Nighty-night, gents.
            • jeff hammondJ Offline
              (marked 'this sh*t' in the pic below)
              πŸ˜†
              oh.. that.. thanks for clearing it up.
              but i don't know.. rich's suggestion sounds like a good start..
              if not, maybe post a hidden line view.
              • cottyC Offline
                cotty
                For me, it looks like a displacement problem because of very long but narrow tiangles. Do you have a view of the hidden lines?
                my SketchUp gallery
                • StinkieS Offline
                  Stinkie
                  Looks like it, yes, but I'm not using any displacement.
                  Did as Rich suggested. No change.
                  Here's the thingy.
                  wtf.skp
                  • cottyC Offline
                    cotty
                    The faces are triangulated while the export for a renderer and the very long and narrow faces become a problem. In the following example, I used Artisans knife tool to shorten those faces and the problem was solved...
                    (Rendered with Indigo and "random triangle color" option)
                    my SketchUp gallery
                    • BoxB Offline
                      I suspect it's caused by round corner struggling to make the tiny faces needed. The pyramid isn't "small" but the four edges coming together at a sharp angle and the smallness of your rounding are forcing it to make some very tiny triangles.
                      Perhaps if you scale up before using round corner it wont tear.
                      • StinkieS Offline
                        Stinkie
                        Box, thanks for the suggestion. However, I did scale the pyramid up before bevelling.
                        Cotty, you're a bl**dy genius. I am going to try your suggestion right now!
                        Edit: works! Cotty -thanks so much. The rest of you: shakes head dissaprovingly
                        About the diamonds etc, I lied.
                        • StinkieS Offline
                          Stinkie
                          Hmmm ... got the problem in other models as well. SU doesn't like tight bevels, it seems. Maybe it's finally time to get that new Modo license. grumbles
                            SU doesn't obey normal modeling principles. NGons = bad mesh and uv's.
                            Triangulation equals messy uv's.
                            • StinkieS Offline
                              Stinkie
                              Yeah ... I knew that. Hadn't realised so far it was this bad, though. Maybe I ought to try TT's Quad Face Tools.
