    Geometry weirdness
    19 Posts 6 Posters 1.5k Views 6 Watching
    • cottyC
      cotty
      Perhaps some very acute angles?
      my SketchUp gallery
      • StinkieS
        Stinkie
        Cotty, Jeffy, Kimmy,
        What you're looking at, is a pyramid shape. I've bevelled the edges that meet in the pyramid's point, using RoundCorner. The black 'lines' you see in the render (marked 'this sht' in the pic below), should not be there. Looks like polys going 'right, friday night, let's get hammered and fck sh*t up'.
        Yours,
        Tommy
          have you double verts?
          • StinkieS
            Stinkie
            No idea, Rich. How do I check? (I did run TT's CleanUp tools -render looked similar.)
            I'll upload the pyramid thingy tommorow morning. Thanks for any help. Let me know what kind of drugs you prefer.
              Run Fredo's Remove Lonely Vertex tool. It'll mark and remove any shitty stuff.
              But share it when you get time.
              • StinkieS
                Stinkie
                Oh, excellent! I'll try that.
                But share it when you get time.[/quote]
                I will.
                Nighty-night, gents.
                • jeff hammondJ
                  (marked 'this sh*t' in the pic below)
                  πŸ˜†
                  oh.. that.. thanks for clearing it up.
                  but i don't know.. rich's suggestion sounds like a good start..
                  if not, maybe post a hidden line view.
                  • cottyC
                    cotty
                    For me, it looks like a displacement problem because of very long but narrow tiangles. Do you have a view of the hidden lines?
                    my SketchUp gallery
                    • StinkieS
                      Stinkie
                      Looks like it, yes, but I'm not using any displacement.
                      Did as Rich suggested. No change.
                      Here's the thingy.
                      wtf.skp
                      • cottyC
                        cotty
                        The faces are triangulated while the export for a renderer and the very long and narrow faces become a problem. In the following example, I used Artisans knife tool to shorten those faces and the problem was solved...
                        (Rendered with Indigo and "random triangle color" option)
                        my SketchUp gallery
                        • BoxB
                          I suspect it's caused by round corner struggling to make the tiny faces needed. The pyramid isn't "small" but the four edges coming together at a sharp angle and the smallness of your rounding are forcing it to make some very tiny triangles.
                          Perhaps if you scale up before using round corner it wont tear.
                          • StinkieS
                            Stinkie
                            Box, thanks for the suggestion. However, I did scale the pyramid up before bevelling.
                            Cotty, you're a bl**dy genius. I am going to try your suggestion right now!
                            Edit: works! Cotty -thanks so much. The rest of you: shakes head dissaprovingly
                            About the diamonds etc, I lied.
                            • StinkieS
                              Stinkie
                              Hmmm ... got the problem in other models as well. SU doesn't like tight bevels, it seems. Maybe it's finally time to get that new Modo license. grumbles
                                SU doesn't obey normal modeling principles. NGons = bad mesh and uv's.
                                Triangulation equals messy uv's.
                                • StinkieS
                                  Stinkie
                                  Yeah ... I knew that. Hadn't realised so far it was this bad, though. Maybe I ought to try TT's Quad Face Tools.
