    Geometry weirdness
    19 Posts 6 Posters 1.5k Views 6 Watching
    • FrederikF
      Frederik
      rephrase the question?
      I agree...
      I saw the post yesterday, but didn't know exactly what to look for... 😳
      Left it to let others chime in... πŸ˜„
      What about a part of the model, where this issue is present...?
      Cheers
      Kim Frederik
      • cottyC
        cotty
        Perhaps some very acute angles?
        my SketchUp gallery
        • StinkieS
          Stinkie
          Cotty, Jeffy, Kimmy,
          What you're looking at, is a pyramid shape. I've bevelled the edges that meet in the pyramid's point, using RoundCorner. The black 'lines' you see in the render (marked 'this sht' in the pic below), should not be there. Looks like polys going 'right, friday night, let's get hammered and fck sh*t up'.
          Yours,
          Tommy
            have you double verts?
            • StinkieS
              Stinkie
              No idea, Rich. How do I check? (I did run TT's CleanUp tools -render looked similar.)
              I'll upload the pyramid thingy tommorow morning. Thanks for any help. Let me know what kind of drugs you prefer.
                Run Fredo's Remove Lonely Vertex tool. It'll mark and remove any shitty stuff.
                But share it when you get time.
                • StinkieS
                  Stinkie
                  Oh, excellent! I'll try that.
                  But share it when you get time.[/quote]
                  I will.
                  Nighty-night, gents.
                  • jeff hammondJ
                    (marked 'this sh*t' in the pic below)
                    πŸ˜†
                    oh.. that.. thanks for clearing it up.
                    but i don't know.. rich's suggestion sounds like a good start..
                    if not, maybe post a hidden line view.
                    • cottyC
                      cotty
                      For me, it looks like a displacement problem because of very long but narrow tiangles. Do you have a view of the hidden lines?
                      my SketchUp gallery
                      • StinkieS
                        Stinkie
                        Looks like it, yes, but I'm not using any displacement.
                        Did as Rich suggested. No change.
                        Here's the thingy.
                        wtf.skp
                        • cottyC
                          cotty
                          The faces are triangulated while the export for a renderer and the very long and narrow faces become a problem. In the following example, I used Artisans knife tool to shorten those faces and the problem was solved...
                          (Rendered with Indigo and "random triangle color" option)
                          my SketchUp gallery
                          • BoxB
                            I suspect it's caused by round corner struggling to make the tiny faces needed. The pyramid isn't "small" but the four edges coming together at a sharp angle and the smallness of your rounding are forcing it to make some very tiny triangles.
                            Perhaps if you scale up before using round corner it wont tear.
                            • StinkieS
                              Stinkie
                              Box, thanks for the suggestion. However, I did scale the pyramid up before bevelling.
                              Cotty, you're a bl**dy genius. I am going to try your suggestion right now!
                              Edit: works! Cotty -thanks so much. The rest of you: shakes head dissaprovingly
                              About the diamonds etc, I lied.
                              • StinkieS
                                Stinkie
                                Hmmm ... got the problem in other models as well. SU doesn't like tight bevels, it seems. Maybe it's finally time to get that new Modo license. grumbles
                                  SU doesn't obey normal modeling principles. NGons = bad mesh and uv's.
                                  Triangulation equals messy uv's.
                                  • StinkieS
                                    Stinkie
                                    Yeah ... I knew that. Hadn't realised so far it was this bad, though. Maybe I ought to try TT's Quad Face Tools.
