    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 764.1k Views 143 Watching
      Anastasia_0111
      What can be the reason of such error of TopoShaper?
      It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
        Put your SKP, that can be helping! πŸ˜‰
        Save as V6 for a more large audience! πŸ˜‰
          Anastasia_0111
          As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
          This is a full text of the error:
          body_lib6g6.rbe
          2254
          block in proximity_point_curve_by_circle
          body_lib6g6.rbe
          2249
          each
          body_lib6g6.rbe
          2249
          toposhaperalgo.rbe
          2419
          block in altitude_at_point
          toposhaperalgo.rbe
          2417
          each
          toposhaperalgo.rbe
          2417
          altitude_at_point
          toposhaperalgo.rbe
          2390
          altitude_multi
          toposhaperalgo.rbe
          427
          block in top_processing
          toposhaperalgo.rbe
          425
          each
          toposhaperalgo.rbe
          425
          each_with_index
          toposhaperalgo.rbe
          425
          top_processing
          toposhapertool.rbe
          574
          algo_processing
          toposhapertool.rbe
          666
          execute_validate
          toposhaperpalette.rbe
          130
          execute_from_palette
          76
          notify_from_palette
          518
          call
          518
          block (2 levels) in palette_validate
          body_lib6palette.rbe
          3596
          call
          3596
          execute_button
          3401
          onLButtonUp
          lib6palette.rbe
          91
          onLButtonUp
          toposhapertool.rbe
          984
          onLButtonUp
          • fredo6F Offline
            fredo6
            @Anastasia_0111
            Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
            Many thanks
            Fredo
            • P Offline
              peggy1124
              Thank you Fredo
              amazing plugin
              • K Offline
                Keniff
                Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
                Any help appreciated
                • K Offline
                  Keniff
                  Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
                  • fredo6F Offline
                    fredo6
                    Very difficult to help if you do not post the model
                    Fredo
                      akaraphon
                      hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
                      ps. thank you
                        akaraphon
                        hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
                        thank you
                        • fredo6F Offline
                          fredo6
                          If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
                          Anyway, the best is that you post your model so that I can have a look.
                          Fredo
                            alpro
                            Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
                            A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
                              alpro
                              That's great Fredo, look forward to it.
                              • fredo6F Offline
                                fredo6
                                It is complex (it involves constrained Delaunay triangulation), but I finally built an algorithm (I use it already in FredoCorner). I will integrate it in TopoShaper when I can, along with a GUI refresh. This would look like a "from Contour", where you can also influence the terrain with additional guide points.
                                Fredo
                                • pbacotP Offline
                                  What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
                                  My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
                                  • fredo6F Offline
                                    fredo6
                                    In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
                                    But I'll think about what can be done, especially for roads.
                                    Fredo
                                    • K Offline
                                      KrisM
                                      This would be GREAT addition to this plugin. I do this work manually at present and it is tedious to say the least. This would be a great time saver.
                                      KrisM
                                      • PixeroP Offline
                                        Pixero
                                        Something interactive like this for roads would be superb.
                                        https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
                                        And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/23047/1/gupea_2077_23047_1.pdf
                                        • fredo6F Offline
                                          fredo6
                                          I think there is already a Plugin, InstantRoad by ValiArchitect.
                                          Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
                                          Fredo
                                          • PixeroP Offline
                                            Pixero
                                            But Instant road isn't interactive like in the link.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
