    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
      dlannetts
      Hello,
      Great plugin, however I am having an issue, after generating the terrain from guide points, using the toolbar, and clicking off elsewhere, the toolbar disappears and I can't seem to get it back to modify the terrain. How can I get the toolbar back after it has disappeared?
      David.
      • fredo6F
        @dlannetts said:
        Hello,
        David.
        Can you open the Ruby console, as there may be an error.
        Did the terrain generate correctly by the way?
          simonhaufe
          I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
          Any ideas and suggestions are most welcome!! 😎 β˜€
          Best Regards Simon
          • fredo6F
            Best Regards Simon
            I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
            So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
              rspierenburg
              I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
              Toposhaper Error
              • fredo6F
                It would be helpful that you attach your model so that I can investigate. Thanks.
                  rspierenburg
                  Thanks, Here is the model.
                  Topography.skp
                  • fredo6F
                    @Rspierenburg
                    You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
                    Note that your model seems to have some points which create peaks.
                    Rspierenburg - Topography - SU2015.skp
                      Anastasia_0111
                      What can be the reason of such error of TopoShaper?
                      It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
                        Put your SKP, that can be helping! πŸ˜‰
                        Save as V6 for a more large audience! πŸ˜‰
                          Anastasia_0111
                          As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
                          This is a full text of the error:
                          body_lib6g6.rbe
                          2254
                          block in proximity_point_curve_by_circle
                          body_lib6g6.rbe
                          2249
                          each
                          body_lib6g6.rbe
                          2249
                          toposhaperalgo.rbe
                          2419
                          block in altitude_at_point
                          toposhaperalgo.rbe
                          2417
                          each
                          toposhaperalgo.rbe
                          2417
                          altitude_at_point
                          toposhaperalgo.rbe
                          2390
                          altitude_multi
                          toposhaperalgo.rbe
                          427
                          block in top_processing
                          toposhaperalgo.rbe
                          425
                          each
                          toposhaperalgo.rbe
                          425
                          each_with_index
                          toposhaperalgo.rbe
                          425
                          top_processing
                          toposhapertool.rbe
                          574
                          algo_processing
                          toposhapertool.rbe
                          666
                          execute_validate
                          toposhaperpalette.rbe
                          130
                          execute_from_palette
                          76
                          notify_from_palette
                          518
                          call
                          518
                          block (2 levels) in palette_validate
                          body_lib6palette.rbe
                          3596
                          call
                          3596
                          execute_button
                          3401
                          onLButtonUp
                          lib6palette.rbe
                          91
                          onLButtonUp
                          toposhapertool.rbe
                          984
                          onLButtonUp
                          • fredo6F
                            @Anastasia_0111
                            Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
                            Many thanks
                            • P
                              peggy1124
                              Thank you Fredo
                              amazing plugin
                              • K
                                Keniff
                                Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
                                Any help appreciated
                                • K
                                  Keniff
                                  Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
                                  • fredo6F
                                    Very difficult to help if you do not post the model
                                      akaraphon
                                      hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
                                      ps. thank you
                                        akaraphon
                                        hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
                                        thank you
                                        • fredo6F
                                          If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
                                          Anyway, the best is that you post your model so that I can have a look.
                                            alpro
                                            Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
                                            A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
