    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 369.8k Views 57 Watching
      There are lots of 'gaps' in your contours etc which are probably causing the issues.
      You could always draw a few lines in to heal the critical ones before doing anything else...
      I ran your contour-lines [without any other processing] through the Sandbox Tools > From Contours.
      After some processing it made a complex terrain mesh...Capture.PNGI assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." πŸ˜‰
      • fredo6F Offline
        fredo6
        The erreor 'reference to deleted vertex' may occur in some situations and not easy to fix.
        I suggest you use the mode "Erase and Create" rather than deform.
        Were you processing all (or many) contours at once?
        Fredo
          matt.gordon320
          After some processing it made a complex terrain mesh...[attachment=0:28k6bpaf]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:28k6bpaf]I assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." πŸ˜‰
          Yes, I tried running the "From Contours", and it worked fine, I was just trying to test the difference in file size that Fredo's tool might save. I'm pretty much the only one in the office who bothers to try to keep file size down, so I figured I'd try it.
          Fredo
          I'll try to see if "Erase and Create" will work for me. I was running all of them at once. It's my first time using the tool 😳 so I was more just testing than anything. Is running all of them at once a terrible idea, like I'm currently realizing it might be?
            marszbrowse
            Hi There,
            First of all thanks for all your good work!
            I've installed your plugin(s) and all worked like a charm. Unfortunately I've been kind of a dumb ass by moving some of the files out of the Curvizard folder. Tought they were in the wrong folder at the time. Since then on every load, SU keeps reporting missing *.rb files from the loader. Even with all the Curvizard files removed and all so with them installed (and working) What can I do, there is no info about this in the manual.
            TIA
            Marsz
              @marszbrowse said:
              Hi There,
              I've installed your plugin(s) and all worked like a charm. Unfortunately I've been kind of a dumb ass by moving some of the files out of the Curvizard folder. Thought they were in the wrong folder at the time. Since then on every load, SU keeps reporting missing *.rb files from the loader. Even with all the Curvizard files removed and all so with them installed (and working) What can I do, there is no info about this in the manual.
              TIA
              Marsz
              I'm afraid tools' authors can't make accommodations for every user's stupidity... πŸ˜’
              Even some full error messages from you would be helpful - rather than your prΓ©cis...
              Re-get all of the needed files/subfolders again.
              Now look at what is in these.
              Find all matching files/subfolders inside the Plugins folder and remove them.
              Now reinstall the newly got files correctly...
              There are clear instructions about where the files/subfolders and helpers etc go, reread that and make sure you know what to do... πŸ˜•
              • fredo6F Offline
                fredo6
                Here is the footprint of Curvizard files and folders, so that you could reorganize your Plugins directory
                Fredo
                  Hi Fredo,
                  The tooltips for Smooth contours are showing as Simplify Contours for the toolbar icons, onscreen HUD and in the Status bar.
                  The tool works as expected it is just the tooltips that are incorrect.
                  Great update by the way πŸ‘
                    marszbrowse
                    Thanks TIG and Fredo6,
                    Of course I realize that stupidity isn't something you should support. As a matter of fact you should do nothing at all, and I appreciate your work deeply. So Respect from my side.
                    I've searched my whole folder file by file, and first removed all the files that also came in the zip. Thereby completely installed the plugin.
                    Now when I open a file, which I've recently edited, it keeps giving the error:
                    Error Loading File bootstrap_Curvizard.rb
                    uninitialized constant Curvizard::T6Error Loading File CurvizardAlgo.rb
                    uninitialized constant Curvizard::T6Error Loading File CurvizardTool.rb
                    Thought a new install will fix this, but it won't. My folders are now exactly as listed above, and works super! Regardless of the load error I keep getting.
                    I there a location I could look?
                    Thanks for your help.
                    Marsz
                    • fredo6F Offline
                      fredo6
                      @Marsz
                      This seems to be an error related to the installation of LibFredo6.
                      You should check the foot print (just one file, LibFredo6.rb and one folder LIBFREDO6_Dir_47).
                      Fredo
                      • humbertorbH Offline
                        humbertorb
                        Hi Fredo,
                        First: you tools are great, thank you very much.
                        I installed Curvizard 1.2d today and got similar errors as above:
                        Error Loading File __loader.rb
                        uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                        uninitialized constant Curviloft::T6Error Loading File bootstrap_Curvizard.rb
                        uninitialized constant Curvizard::T6Error Loading File CurviloftAlgo.rb
                        uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                        uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                        uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                        uninitialized constant Curviloft::T6Error Loading File CurvizardAlgo.rb
                        uninitialized constant Curvizard::T6Error Loading File FredoTools.rb
                        uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
                        I have LibFredo6 installed:
                        LibFredo6.rb
                        LIBFREDO6_Dir_47
                        Are in my plugins directory and I'm running other Fredo plugins (Round Corner, Tools on Surface) without any problem.
                        Am I missing anything?
                        PS: my Sketchup is version 8.0.15157 running on a Mac OS X 10.6.8
                          It looks like an installation error. My guess is that you either took the contents of the Curvizard_Dir_11 folder out and dumped them into the Plugins folder or you have that folder inside another folder which makes them not load correctly. Go back to the first post where the footprint for the plugin is clearly shown and make sure yours looks like that.
                          • V Offline
                            vame9
                            really amazing and usfull ty
                              humbertorb
                              Thanks Dave! That was exactly the case. The way I read the instructions gave me the impression I had to dump all the files instead of moving the directory.
                              Cheers
                              HB
                              • jeff hammondJ Offline
                                jeff hammond
                                i haven't checked this out since last time i talked with you about it. it's awesome πŸ‘
                                (and i still havent thoroughly checked it out.. only weld and smooth)
                                (havent read the thread yet either 😳 )
                                not sure if youd be into it but with make curves, a speed mode would be great.. hypothetical usage:
                                β€’ push W (or whatever your welding shortcut is)
                                β€’ the curvizard cursor comes up
                                β€’ select your line (i.e.- up til now, everything is the same except there's no palette up top)
                                β€’ the line turns orange except only for a split second.. a flash.. then the line welds as per your previous(? or otherwise customizable) settings **
                                β€’ the tool exits (maybe back to the previous tool if possible or even practical?)
                                β€’ then there's also multispeedβ„’ mode which is ⇧W (or whatever).. that makes the curve but doesn't exit.. its ready for another..
                                β€’ click blank space to exit..
                                i dont' really think they should be added to the icon menu because it might clutter it up but it doesn't really matter.. these are mainly hotkey tools
                                ala jean.. just ideas πŸ’š
                                **[edit] - basically, it's acting like my current welding plugin with the benefit of not needing to preselect as you have your own cursor...
                                also, the flash gives some visual feedback in two ways.. first, you get to see that something actually happened and you'll also see what actually was made into a curve.. (whereas with recurve, i always (every single time) find myself reselecting the line to make sure a) the plugin worked and b) to see what was welded..
                                • you have control over the settings
                                dotdotdot
                                • fredo6F Offline
                                  fredo6
                                  Jeff,
                                  I understand the requirement, but the capability of Curvizard to know exactly which segments will form a curve is limited (the Follow mode is based on angle continuity).
                                  However, Curvizard include an autoexit feature (See Default parameters). You preselect the segments by the SU Selection tool and then call Curvizard (icon or context menu) that will just make them curves and exit. I can easily do the brief highlight (actually I implemented the feature and disabled it). Instead, you have the highlight in pale green of any SU curve you mouse over.
                                  Fredo
                                    rv1974
                                    I have a feeling that curvizard could help me in my specific case:
                                    Here's some kind of square put on very primitive ugly mesh. I'd like to refine (normalize, smooth out) the curb's polyline (copied upward) to redefine the squre surface.
                                    Could anybody post step-by-step instructions? the plugin became a bit over-complicated πŸ˜•
                                    Thanks in advance.
                                    fred.skp
                                    • V Offline
                                      victor hugo
                                      RV1974 I'm not a user of this plugin but I saw the demo on the attached link, it looks it will help whit what you're wanting to do.
                                      (artisan4sketchup.com)
                                      other one can be Vertex tools at http://www.thomthom.net/software/vertex_tools/
                                        jeff hammond
                                        Fredo
                                        oh.. yeah.. that's good for preselecting then welding πŸ‘
                                        pretty much what i was imagining to myself earlier in the thread.. ha! 😳
                                        Jeff,
                                        right.. that's how recurve is set up too.. the angle is 1 radian.. the main reason i use recurve is because you only have to select one segment then it follows/selects anything under a radian.. (well, also because i don't have to answer any questions at the end as in weld.rb)
                                        i was thinking in the speed idea, the follow mode is using whatever number is listed in the palette.. (defualt 40 but if i change it to 60 at some point, then it will use that next time i use the speed mode)
                                        [sorry for this 'speed mode' talk.. sounds kinda corny.. i don't know what else to call it though]
                                        further, the mode could combine preselect & no selection.. (everything is already written/functioning.. i'm just suggesting (in my non-ruby-knowing-head) moving some of the wires around for a different style of user interaction)... usage-
                                        β€’ select a segment
                                        β€’ press keyshortcut
                                        β€’ curvizard's follow mode kick in then selects accordingly and welds
                                        β€’ auto exit
                                        -AND-
                                        β€’ have nothing selected
                                        β€’ press the same keyshortcut
                                        β€’ curvizard's cursor comes up
                                        β€’ select a segment, follow mode, weld
                                        β€’ auto exit
                                        i honestly think that would be the best welding tool yet.. by far
                                        not sure how others would feel about it but i can't grasp someone not liking it much better than weld.rb
                                        anyway, thanks for listening πŸ˜„
                                        dotdotdot
                                        • fredo6F Offline
                                          fredo6
                                          NEW RELEASE: Curvizard v1.2a - 18 May 13
                                          Curvizard 1.2 is an technical update dedicated to the management of big number of edges and contours. It also fixes bugs related to operating on duplicated groups[/list]
                                          Duplicated groups are groups which are just been copied from an existing group (via the Move+ tool or Copy / paste). Until they are edited, Sketchup treats them as pseudo components. This creates a lot of issues for Ruby scripts and is the source of potential crashes or errors of type "Reference to deleted entity".
                                          Here is a short video showing the visual effect on a Make Curve process on 13,000 edges.
                                          Curvizard 1.1 requires an upgrade to LibFredo6 4.9 or higher.
                                          See main post of this thread for Download.
                                          Fredo
                                          • CadFatherC Offline
                                            CadFather
                                            Thanks Fredo ...some alternative icons just in case.
                                            CV.zip
                                            • 6
                                            • 9
                                            • 10
                                            • 4 / 10
