    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • V
      victor hugo
      Pretty useful plugin!!!
      I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
      Thanks.
      • cottyC
        cotty
        1.1c or 1.1d?
        my SketchUp gallery
        • V
          victor hugo
          I had 1.1c and just did 1.1d and the attched is what is showing
          Thanks.
          • cottyC
            cotty
            You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
            my SketchUp gallery
            • guanjinG
              guanjin
              I am also, but does not affect use.
                small08
                Amazing work Fredo, Thank-you!
                  matt.gordon320
                  Hi Fredo,
                  I was wondering if you might be able to take a look at my office's model to see what might be causing the error(s) I'm getting? I've attached both the model and the error report.
                  Matt
                  Master Topo Clean ERROR.skp
                  Ruby Error - Curvizard#simplify_curve - 10-Dec-12 13_43_35.txt
                    Matt
                    What are you trying to do when you get the error message ?
                    Your post is too scant. ๐Ÿ˜•
                      matt.gordon320
                      My apologies, my message is absolutely lacking in any detail ๐Ÿ˜ณ
                      I've brought in a dwg containing topographic information from a civil consultants's office, and I'm trying to use Curvizard to simplify the contours. When I do, the interface of SketchUp pauses for a second, then comes up with an error message window containing the information in the attached text report. I can't quite figure out what the error is, or whether it's something that I introduced through cleaning up the DWG, or whether it's something that is just lost in translation from AutoCAD => SketchUp.
                      Hope that's better ๐Ÿ˜„
                      Matt
                        There are lots of 'gaps' in your contours etc which are probably causing the issues.
                        You could always draw a few lines in to heal the critical ones before doing anything else...
                        I ran your contour-lines [without any other processing] through the Sandbox Tools > From Contours.
                        After some processing it made a complex terrain mesh...Capture.PNGI assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." ๐Ÿ˜‰
                        • fredo6F
                          The erreor 'reference to deleted vertex' may occur in some situations and not easy to fix.
                          I suggest you use the mode "Erase and Create" rather than deform.
                          Were you processing all (or many) contours at once?
                            matt.gordon320
                            After some processing it made a complex terrain mesh...[attachment=0:28k6bpaf]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:28k6bpaf]I assume this is something like you hoped for ? Perhaps you need to choose your tools... "When the only tool you have is a hammer, everything starts to look like a nail..." ๐Ÿ˜‰
                            Yes, I tried running the "From Contours", and it worked fine, I was just trying to test the difference in file size that Fredo's tool might save. I'm pretty much the only one in the office who bothers to try to keep file size down, so I figured I'd try it.
                            I'll try to see if "Erase and Create" will work for me. I was running all of them at once. It's my first time using the tool ๐Ÿ˜ณ so I was more just testing than anything. Is running all of them at once a terrible idea, like I'm currently realizing it might be?
                              marszbrowse
                              Hi There,
                              First of all thanks for all your good work!
                              I've installed your plugin(s) and all worked like a charm. Unfortunately I've been kind of a dumb ass by moving some of the files out of the Curvizard folder. Tought they were in the wrong folder at the time. Since then on every load, SU keeps reporting missing *.rb files from the loader. Even with all the Curvizard files removed and all so with them installed (and working) What can I do, there is no info about this in the manual.
                              TIA
                              Marsz
                                @marszbrowse said:
                                Hi There,
                                I've installed your plugin(s) and all worked like a charm. Unfortunately I've been kind of a dumb ass by moving some of the files out of the Curvizard folder. Thought they were in the wrong folder at the time. Since then on every load, SU keeps reporting missing *.rb files from the loader. Even with all the Curvizard files removed and all so with them installed (and working) What can I do, there is no info about this in the manual.
                                TIA
                                Marsz
                                I'm afraid tools' authors can't make accommodations for every user's stupidity... ๐Ÿ˜’
                                Even some full error messages from you would be helpful - rather than your prรฉcis...
                                Re-get all of the needed files/subfolders again.
                                Now look at what is in these.
                                Find all matching files/subfolders inside the Plugins folder and remove them.
                                Now reinstall the newly got files correctly...
                                There are clear instructions about where the files/subfolders and helpers etc go, reread that and make sure you know what to do... ๐Ÿ˜•
                                • fredo6F
                                  Here is the footprint of Curvizard files and folders, so that you could reorganize your Plugins directory
                                    Hi Fredo,
                                    The tooltips for Smooth contours are showing as Simplify Contours for the toolbar icons, onscreen HUD and in the Status bar.
                                    The tool works as expected it is just the tooltips that are incorrect.
                                    Great update by the way ๐Ÿ‘
                                      marszbrowse
                                      Thanks TIG and Fredo6,
                                      Of course I realize that stupidity isn't something you should support. As a matter of fact you should do nothing at all, and I appreciate your work deeply. So Respect from my side.
                                      I've searched my whole folder file by file, and first removed all the files that also came in the zip. Thereby completely installed the plugin.
                                      Now when I open a file, which I've recently edited, it keeps giving the error:
                                      Error Loading File bootstrap_Curvizard.rb
                                      uninitialized constant Curvizard::T6Error Loading File CurvizardAlgo.rb
                                      uninitialized constant Curvizard::T6Error Loading File CurvizardTool.rb
                                      Thought a new install will fix this, but it won't. My folders are now exactly as listed above, and works super! Regardless of the load error I keep getting.
                                      I there a location I could look?
                                      Thanks for your help.
                                      Marsz
                                      • fredo6F
                                        @Marsz
                                        This seems to be an error related to the installation of LibFredo6.
                                        You should check the foot print (just one file, LibFredo6.rb and one folder LIBFREDO6_Dir_47).
                                        • humbertorbH
                                          humbertorb
                                          Hi Fredo,
                                          First: you tools are great, thank you very much.
                                          I installed Curvizard 1.2d today and got similar errors as above:
                                          Error Loading File __loader.rb
                                          uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                                          uninitialized constant Curviloft::T6Error Loading File bootstrap_Curvizard.rb
                                          uninitialized constant Curvizard::T6Error Loading File CurviloftAlgo.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                          uninitialized constant Curviloft::T6Error Loading File CurvizardAlgo.rb
                                          uninitialized constant Curvizard::T6Error Loading File FredoTools.rb
                                          uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
                                          I have LibFredo6 installed:
                                          LibFredo6.rb
                                          LIBFREDO6_Dir_47
                                          Are in my plugins directory and I'm running other Fredo plugins (Round Corner, Tools on Surface) without any problem.
                                          Am I missing anything?
                                          PS: my Sketchup is version 8.0.15157 running on a Mac OS X 10.6.8
                                            It looks like an installation error. My guess is that you either took the contents of the Curvizard_Dir_11 folder out and dumped them into the Plugins folder or you have that folder inside another folder which makes them not load correctly. Go back to the first post where the footprint for the plugin is clearly shown and make sure yours looks like that.
                                            • 4 / 10
