    Joint Push Pull -- VERY slow
    20 Posts 7 Posters 1.4k Views 7 Watching
    • jeff hammondJ Offline
      jeff hammond
      i can't be for sure if this started with the M3 update or not but it is a recent bug(?)
      if i draw a sphere using two 24 segment circles (i.e.- 288 faces) then use JPP, the operation takes 72 seconds to complete 😲
      can others test and report their findings? the sphere offset should be almost instant iirc..
      maybe someone could test with a similar setup as mine so i can begin to narrow it down?
      OS X (10.7.4)
      Sketchup 8 M3 (8.0.14345)
      mid2010 mbp -- nvidia gt330m, 4GB ram, 2.66ghz i7
      thanks!
      dotdotdot
        4 secs on Windows
          iirc?
            jeff hammond
            @rich o brien said:
            iirc?
            I thought you were internerd enough to know that one..
            if I remember correctly
            (JPP used to be a lot faster iirc)
            dotdotdot
              2.17 seconds on my PC
                jeff hammond
                right. that's what it should be like.
                now waiting for a separate lion/m3 report.
                thanks fellas
                dotdotdot
                  Sorry to disappoint but geek speak isn't in my vocab.
                    Quasi instant in V6 Xp Windows! πŸ’š
                      jeff hammond
                      re-downloaded the latest version just in case i inadvertently downshifted it..
                      installed only JPP and tried again..
                      same problem.
                      edit-- tried it with su7 and the latest jpp version and it's super fast again.. around 1 second for the sphere..
                      dotdotdot
                      • wind-borneW Offline
                        wind-borne
                        same Lion and SU, older, less powerful machine
                        7 sec on SU8
                        2 sec on SU7
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                          jeff hammond
                          7 sec on SU8
                          2 sec on SU7
                          ugh.. something weird on my computers then (same thing happening on my macpro)
                          not a good time for this to be happening.. no time to really troubleshoot and I need the plugin.
                          (taking hours to offset certain surfaces when it should be minutes 😞 )
                          edit. oh wait.. I can use su7 to JPP for now.. doh
                          will figure out the problem later
                          thanks all
                          dotdotdot
                            jeff hammond
                            i moved my plist to the desktop then relaunched sketchup (basically, resetting su)..
                            the plugin worked as expected.. (not really in the mood for setting everything back up to my liking atm (rich?) so i put the old one back for now... strange that i have two computers doing the same thing.. something i have on both systems must of done something to my plist ?? if it happens again, i'll try to sniff it out..)
                            dotdotdot
                              Automated teller machine πŸ‘
                                jeff hammond
                                πŸ‘
                                dotdotdot
                                  redlerred7
                                  4 seconds (same as always)
                                    7 sec on SU8
                                    2 sec on SU7
                                    thanks all
                                    Are you on Lion Jeff?
                                    There is a performance issue under OSX if a plugin updates the statusbar text (uses Sketchup.status_text='...'). It becomes very slow if that method is called in every iteration inside a loop. The reason I wondered if you where also on Lion Jeff was that I was theorizing that something changed in the OS that made the text drawing faster.
                                      Ah, I noticed your computer specs in the first post now. My theory failed! 😞
                                        jeff hammond
                                        thanks red.
                                        haha. thanks for chiming in regardless πŸ˜‰
                                        dotdotdot
                                          Jeff, I just tried the same sphere with JPP on my MacBook with OSX 10.6.8. It was just as fast as on my PC.
                                            jeff hammond
                                            yeah.. i had a corrupt plist file.. still wandering how it became corrupted in the first place but i'm back to normal now..
                                            i briefly tried to find something weird in there and i came across these two entries..
                                            there's a jointpushpull and a joinpushpull1 (no 't' in joint?)
                                            i'm not sure if both of those should be in there and if not, i'm not sure how the extra one came into play.. maybe an older version?
                                            (i've been using this same plist for a while now.. transferred my su7 settings to it etc.. i dread refreshing my su environment but maybe this is a clue that i should do it now πŸ˜„ )
                                            dotdotdot
