    Joint Push Pull -- VERY slow
    20 Posts 7 Posters 1.8k Views 7 Watching
    • wind-borneW Offline
      wind-borne
      same Lion and SU, older, less powerful machine
      7 sec on SU8
      2 sec on SU7
      "To read between the lines was easier than to follow the text."OSX 10.11.6
      %(#BF80BF)[SU 8 pro
      • jeff hammondJ Offline
        7 sec on SU8
        2 sec on SU7
        ugh.. something weird on my computers then (same thing happening on my macpro)
        not a good time for this to be happening.. no time to really troubleshoot and I need the plugin.
        (taking hours to offset certain surfaces when it should be minutes 😞 )
        edit. oh wait.. I can use su7 to JPP for now.. doh
        will figure out the problem later
        thanks all
          i moved my plist to the desktop then relaunched sketchup (basically, resetting su)..
          the plugin worked as expected.. (not really in the mood for setting everything back up to my liking atm (rich?) so i put the old one back for now... strange that i have two computers doing the same thing.. something i have on both systems must of done something to my plist ?? if it happens again, i'll try to sniff it out..)
            Automated teller machine πŸ‘
              πŸ‘
                redlerred7
                4 seconds (same as always)
                  7 sec on SU8
                  2 sec on SU7
                  thanks all
                  Are you on Lion Jeff?
                  There is a performance issue under OSX if a plugin updates the statusbar text (uses Sketchup.status_text='...'). It becomes very slow if that method is called in every iteration inside a loop. The reason I wondered if you where also on Lion Jeff was that I was theorizing that something changed in the OS that made the text drawing faster.
                    Ah, I noticed your computer specs in the first post now. My theory failed! 😞
                      thanks red.
                      haha. thanks for chiming in regardless πŸ˜‰
                        Jeff, I just tried the same sphere with JPP on my MacBook with OSX 10.6.8. It was just as fast as on my PC.
                          yeah.. i had a corrupt plist file.. still wandering how it became corrupted in the first place but i'm back to normal now..
                          i briefly tried to find something weird in there and i came across these two entries..
                          there's a jointpushpull and a joinpushpull1 (no 't' in joint?)
                          i'm not sure if both of those should be in there and if not, i'm not sure how the extra one came into play.. maybe an older version?
                          (i've been using this same plist for a while now.. transferred my su7 settings to it etc.. i dread refreshing my su environment but maybe this is a clue that i should do it now πŸ˜„ )
